Thalis
- Joined
- Sep 2, 2020
- Messages
- 362
- Likes
- 218
I got a new MM that can measure low VAC and frequencies so I was very eager to take it on a test run and measure the Line Out of the Fiio E10k. As expected Low or High gain had no effect on the output. But here's where it was a little weird for me. At various frequencies, I get different measurements.
Using Foobar2000 to generate the tones @16bit 44.1kHz @0dB and sending bitperfect to the DAC (WASAPI).
I will list out some (all left channel - I found right channel to be the same) :
10Hz 0.006VAC
20Hz 0.015VAC
50Hz 0.045VAC
60Hz 0.054VAC
100Hz 0.094VAC
200Hz 0.192VAC
400Hz 0.384VAC
600Hz 0.567VAC
1kHz 0.880VAC
3kHz 1.611VAC
4kHz 1.672VAC
5kHz 1.675VAC
7kHz 1.633VAC
10kHz 1.570VAC
11kHz 1.554VAC
15kHz 1.507VAC
17kHz 1.491VAC
18kHz 1.484VAC
19kHz 1.478VAC
20kHz 1.471VAC
I did not expect such margin but I don't know how it relates to the DAC's actual performance. I most definitely did not expect 1kHz to be that low and expected it to be at least 1.5VAC if not nearer to 2VAC. But looking at the higher frequencies it does seem to be within specs? So if I were to make sure my USB mixer (variable output) has a 2VAC output, do I just measure its higher frequencies to try to get close to 2VAC or do I use 1kHz and set it to 2VAC?
Hope to get some feedback.... thank you.
10Hz 0.006VAC
20Hz 0.015VAC
50Hz 0.045VAC
60Hz 0.054VAC
100Hz 0.094VAC
200Hz 0.192VAC
400Hz 0.384VAC
600Hz 0.567VAC
1kHz 0.880VAC
3kHz 1.611VAC
4kHz 1.672VAC
5kHz 1.675VAC
7kHz 1.633VAC
10kHz 1.570VAC
11kHz 1.554VAC
15kHz 1.507VAC
17kHz 1.491VAC
18kHz 1.484VAC
19kHz 1.478VAC
20kHz 1.471VAC
