NAD C658 Streaming DAC Review
Dj7675
Rich, as far as the miniDSP SHD goes, knowing how you've shown a preference through the years for the higher end gear and considering the less than stellar measurements that Amir reported from the review of that unit, I would look more into the miniDSP SHD Studio version. That unit has no analog outputs and costs $300 less, so you can take that money and use it to buy any number of good and affordable DACs that should arguably yield better performance than the analog section of SHD. An issue to consider with both of these miniDSP SHD units is that they don't offer USB input if that's important to you.
Surprised a SINAD of 111 could be a problem. Also SHD has USB input.
bilzebubba
bilzebubba
Yes, it is a Roon Endpoint. It is not certified, but it currently works perfectly for me. Recently volume control was added to the firmware, which it didn’t have before.
Thanks! I currently have 7 Chromecast Audios in the house, feeding various dacs and dac/amps, and I was thinking of getting one of these plus a power amp to replace a newish NAD D3045, which just doesn't drive my 86db speakers very well. I have two further questions, if you don't mind!
1)What I do like about the NAD is how it instantly wakes up from idle when Roon sends a signal to it via the CCA -- will the mini-dsp wake up automatically?
2) If I replace just one of the CCAs with the mini-dsp, would the latency be all that different from the remaining CCAs (i.e., would they more or less play in sync, as they usually do now, or would that require a lot of fiddling?
Thanks in advance!
TimW
Seattle, WA
My SHD is working as a Roon Endpoint. It and the SHD Studio both have USB input.
The SHD is either On or Off, there is no standby or automatic wake up. Not even a trigger input or output. And the power switch is on the back.
Roon won't allow you to group chromecast and non-chromecast streaming devices together.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Not sure if that would work as I understand it, but maybe you could just go CCA optical in on the minidsp, keeping the Chromecast as the endpoint, and still be able to group them...?
I too love my many CCA's...
TimW
Seattle, WA
You can get the SHD Studio and a couple of high performance DAC's to get better performance than the SHD. However, to get that better measured performance along with the balanced connections that the SHD has, you will have to spend significantly more. And the performance of the SHD DAC's is good enough that the improvement is unlikely to be audible.
bilzebubba
That's a great option, yeah thanks! Must say, I was a loyal NAD user (their HQ is also 100km away from me!), having had 5 amps of theirs over the years, but comparing the D3045's output to my 1970s QUAD amp (subjectively) and I am mighty disappointed in its sound. So I am not rushing to buy the C658, and could probably live with the minidsp being always on in exchange for what Dirac might do!
RichB
Massachusetts
It has been a while and still no certification so I have sent a request to MiniDSP for clarification.
- Rich
jam
Montreal
Hmmm... You're right, the SINAD is actually very good. I should have looked at review again. I remembered some characteristic being somewhat disappointing and it was the jitter and noise spectrum that were plentiful although below audibility. As for the USB audio streaming input, I looked at the manual and you're correct, it does have it. My memory must have gotten mixed up with some of their older products where the USB was used only for controlling the unit.
capt.s
The SHD being on all the time with no screen dimming option is an issue for me as bright displays are distracting when watching movies.
Question: Is the screen dimable (I didn't find this in the manual)? Also, a while ago while inquiring with minidsp on this subject, they claimed a firmware update was coming to turn the display off after a period of inactivity. Has this been implemented? Thx
Voo
I heard this unit driving polk l800's at a dealer with dual nad amps bridged. it sounded very good, but I didnt play around with it, just listened.
TimW
Seattle, WA
The screen is not dimmable to my knowledge. Just checked downloads section on my miniDSP profile and it looks like I need to update.
Dj7675
The last firmware enabled screen dimming dims after 30 seconds I believe. It is not user selectable. Minidsp has said it will be user configurable in the future. But for now the entire front display turns off after 30 sec or 1 min. Also a nice feature is if the Minidsp is on another input than Roon (LAN input), it switches automatically to the roon input. Development isn’t fast, but they continue adding bug free features which I appreciate.
phoenixdogfan
Nashville
No USB input, THD + N figures more befitting a product sold in the 1990s, and a $1k+ price tag. That's three strikes.
Bachemar
Does the SHD have an effective Home theater Bypass, that can be selected with one mouse click?
Alexanderc
Florida, USA
capt.s
OK manufacturers, what we need here is a combination of:
-Build quality and HT Bypass implementation of the Parasound P6
-Feature set combination of the MiniDSP SHD and NAD 658
Is that too much to ask?
capt.s
.....It would be interesting to see the P6 tested but I have a feeling the DAC would be no better than one of the better receivers. I did own a 658 for a few days but returned it for all the reasons previous listed and the subwoofer configuration would reset to factory default after a power cycle. I contacted NAD who confirmed this was a know issue. ???? As a seasoned engineer, I can't fathom these days how so many products go to production with inadequate product verification testing. This used to be a firing offense. It's the curse of the in field firmware update 'get out of jail free' card. Hey, just let the customer do the testing..... False economy I'm afraid.
