AndrewDavis
- Joined
- Apr 4, 2019
- Messages
- 220
- Likes
- 431
I appreciate that the panther is observing social distancing by working alone. When will he get a N95 mask and some hand sanitizer?
He has already. The mask is on its head which is not in the picture....I appreciate that the panther is observing social distancing by working alone. When will he get a N95 mask and some hand sanitizer?
It would seem so.OK manufacturers, what we need here is a combination of:
-Build quality and HT Bypass implementation of the Parasound P6
-Feature set combination of the MiniDSP SHD and NAD 658
Is that too much to ask?
Does the SHD have an effective Home theater Bypass, that can be selected with one mouse click?
This is a review and detailed measurements of the NAD C658 streamer and DAC...
Good point. Node 2i appears to be the way to go as a streaming source tooThat looks great if it works. With all the complaints and problems with the c658 (threads on several forums), I think I’d be inclined to go with an Anthem STR integrated over the M33 and buy a separate network streamer.
Sounds like Anthem should upgrade its STR preamp to include these features (and eARC please for those now eschewing AVR)!OK manufacturers, what we need here is a combination of:
No. That's why I chose the C658.
Just to clarify for those interested specifically in HT bypass - The C658 doesn't have a direct HT Bypass either. Both the SHD and C658 have 'analogue' inputs that can be 'kind of' used for that purpose with the C658 having the advantage of being able to assign a fix volume output. So apart from the C658 not requiring you to set the volume to a particular level to match your AVR's calibration there's no difference. They both go through an unnecessary AD/DA conversion and there's no pass through for the subwoofer either. The Parasound HT Bypass is a direct analogue pass-through for L, R and Sub.
Not fully as you suggest. The analogue RCA inputs are converted to digital, processed to some degree if only for volume, and converted back to analog out to the power amp of your choice.
Well, as Amir pointed out, it measures better than spec. And as we all know, even this mediocre performance is well beyond the capabilities of human hearing to actually hear any problem with ...So I am sad, but not terribly surprised, to see that it measures so badly.
As I've said elsewhere, I think NAD/Bluesound's problem with these devices is that they base their OS/firmware on an open source Linux but then choose to make BluOS proprietary and closed source. So they are reliant on 3rd parties for much of the upstream code but can't benefit from the wider community to help fix bugs that may appear.its extremely sad that this device is so plagued by firmware errors, and that they are so slow to fix them.
Try this: generate a test tone file, somewhere in the midrange. 400-1000 Hz or so. Now feed it into the optical or coax input of the C658 and listen. This makes it very easy to hear the problem if it exists there.I had been considering purchasing a c658. For me, it measures well enough and checks all the functionality boxes, but I’m concerned about the popping sounds (from not being able to lock on to an incoming signal?). Should one assume that this is the case on every single unit, or could it be poor QC? If I were to go to my local dealer and listen to one, would I hear the problem? Would it be obvious right away, or do these issues take a while to surface?
Yes, agreed.Still, good measurements point towards good and thoughtfull design, and at this price they should be better than just average.
They would still be in control of what gets into official release builds. Probably the main reason it's not open source is that services like Spotify, Tidal and Dirac – not to mention the rights holders of the music they distribute – get a bit jumpy when around open source projects. All those nasty hacker types poking their noses where they've no business to ...But I think that making it open source or something to that extend, would make it harder for them to control the direction of the development?
As am I. It sounds great and all its features work as advertised.I am still very happy with my C658
Exactly what "features" are your referring to? I have owned all three of these components (STR pre/NAD/P6); I returned the NAD for malfunctions and sold the P6 for lack of room correction. The STR is not going anywhere because of its superb performance and excellent feature set. It isn't a realistic comparison in any case because the STR retails for more than twice the cost of the others. The build quality of the STR is in another league altogether, it has balanced independent sub outs, superb HT bypass, and a more advanced version of ARC that will phase match your subs to the mains. Granted it does not have a built in streamer but that allows the user to choose whatever interface (Yamaha, Denon, Sonos, whatever) they prefer for digital input. I've used all of the major interfaces and settled on Sonos as the most stable and easy to use so I chose a Sonos Port to input my streaming music. The STR has been thoroughly measured at Audioholics with this conclusion "I'm so impressed with how the Anthem STR separates components work in my reference system that I've decided to make them a permanent fixture." Also measured by hometheaterhifi.com with excellent results.Sounds like Anthem should upgrade its STR preamp to include these features (and eARC please for those now eschewing AVR)!
I experienced some light popping sounds at first after sitting idle for 20 minutes or so. But it seems to have stopped that in the last month or so.but I’m concerned about the popping sounds
I'm pretty certain the popping is a software problem - possibly an upstream kernel bug or similar - and maybe only affecting certain combinations of features being in use. I.e. it probably affects all units but only in certain situations and it will almost certainly get fixed in time, if it hasn't already ...If I were to go to my local dealer and listen to one, would I hear the problem? Would it be obvious right away, or do these issues take a while to surface?
