tuga
KLIPPEL LIVE Series1_Part9 - Intermodulation Distortion - Music is More than a Single Tone
This is not correct.Why are you talking about doppler distortion as if I don't know it exists when I literally referenced it in my post. IMD and doppler distortion are two different things, btw. IMD occurs on *all* speakers, not just coaxials. Doppler distortion is unique to coaxials(or any other design where a driver's movement would modulate another driver's somehow).
Maybe I should have said only occurs to a significant degree in coaxial type designs. Regardless it doesn't really seem benign to me in the few cases I've seen it measured in 2-way designs like this one from Erin's Q100 review. It does seem basically irrelevant in 3-way designs.oppler "distortion" is a linear phenomenon (does not produce new tones, rather the original ones are slightly modulated in frequency/phase and sometimes even level) and is only a function of excursion, a lower tone modulating the source position or geometry for a higher tone (and itself, in extreme cases). It happens in all speakers/drivers, even theoretically ideal ones, once there enough excursion but it is a rather benign type of distortion, the sound being slightly "rougher" than without but not cluttered with IMD components hash
Care to share a link etc for info on this? I've never heard or seen any claim like this.To wit, if you have the phase information for distortion products, you can sum independent distortion measurements to get IMD.
With a cellin at 2.5m, i have celling reflections with a listening distance at 2.4 m. Greater is the distance, greater in the dispersion cone.What basically does it mean? View attachment 205051
I'd call this geometry distortion.Maybe I should have said only occurs to a significant degree in coaxial type designs. Regardless it doesn't really seem benign to me in the few cases I've seen it measured in 2-way designs like this one from Erin's Q100 review. It does seem basically irrelevant in 3-way designs.
But the horizontal beam is wider than the vertical one, isn't it?it means what is write : BS marketing
Did you read this summary slide?KLIPPEL LIVE Series1_Part9 - Intermodulation Distortion - Music is More than a Single Tone
yes like all speakers well designed.But the horizontal beam is wider than the vertical one, isn't it?
It's very clearly called doppler distortion in the Genelec Ones white paper, so I dunno. Maybe different sources are referring to different things when they say doppler distortion.I'd call this geometry distortion.
Not to be confused with what Purifi calls it SD modulation: https://purifi-audio.com/2021/10/14/some-speaker-problems-that-needed-solving/
The main
When the woofer works down to bass frequencies (two-way systems) the woofer cone displacement becomes large and this can generate a Doppler shift in the audio radiated by the tweeter. As the woofer cone is making a harmonic movement, this Doppler shift varies harmonically.
However, current coaxial transducers suffer from problems such as sound-colouring diffraction due to discontinuities between the coaxially located drivers. Particularly two-way coaxial designs can have problems with Doppler distortion, having to operate each transducer over a wide frequency band.
What I have highlighted in red is exactly what I post above. The context of Klippel presentation here is for a designer who is diagnosing specific problems and can choose those frequencies appropriately. That notion cannot be applied to a universal set of dual-tones used to compare speakers. What brings out IMD in one driver/speaker is NOT what brings it out in another. This is a showstopper.
Don't confuse what is a design tool with a benchmark metric across multiple products.
Like coax genelecs you mean?yes like all speakers well designed.
yes in orange color.Like coax genelecs you mean?
This is absolutely the correct way of going about things for both you and Amir given the intentions of provided measurements.HD alone with in-room vs anechoic can be vastly different. I actually just wrote a small bit about this elsewhere with 3 examples.
For a DIY'r that's fine. It gives you an idea. And you know your measurement rig/room. For someone like me, I try to provide the most "true" results I possibly can. I try to avoid having to provide measurements that need caveats that the general public won't understand. Thus, my reticence for providing loudspeaker IMD. I've been toying with the idea again, though.
Yes, nomenclature may not be all that clear.It's very clearly called doppler distortion in the Genelec Ones white paper, so I dunno. Maybe different sources are referring to different things when they say doppler distortion.
IMD distortion seems to be very audible according to this paper.
Interesting. thx.Sanctus - in this picture you see differences in amplitude of about 10 dB at 7,5 KHz .
If you are playing bass and cymbals at the same time, even if the volume where lower and the difference between the cone placement where half - you still have a difference at 7,5 KHz at maybe 5 dB modulation which is very audible in real music. It will cause listening fatigue.
In Genelecs white papers of ”the one” they mention the theoretical dissadvantage with coaxials because of this, but they didnt write that there was any compromise in sound quality. The crossover point for ”the one ” is at 320 Hz for 8351 with a step active filter ( probably 24 dB/oct or more ) so maybe the problem goes away then .Interesting. thx.
Wouldn’t that effect also show up during the usual sweeps in the crossover region btw. mid/tweeter when both are active at the same time? Yet, I don’t remember significant distortion for the UniQs at crossover, might be wrong though. Or does the effect, to become significant, require a higher difference in the two frequencies so the mid shows significant cone movements?
Wouldn’t it also be great to ask KEF and or Genelec. Given the time they have been using these coaxials, I would guess they have looked into it, so they wouldn’t bank on a possible problematic technology down the road. Might be wrong here too. But asking wouldn’t hurt ? (Kefs head of development is on this forum isn’t he).
thx.
