New set of graphs for all speakers reviews
sweetchaos
The Curator
BC, Canada
Thanks for adding "Sort By" dropdown. ;)
Is is possible to add a "USD" currency as well? :eek:
I'll gladly gather all the USD prices and send you a spreadsheet.
P
pierre
Switzerland
Even better: you can edit the price directly for each speaker in https://github.com/pierreaubert/spinorama/blob/develop/datas/metadata.py
Log in github, use the edit button, add prices, save, done. If you feel super motivated, I started to add a "review_published" field for measurement but didn't populated the older reviews, then you can also add them.
Going for github will also minimise the risk of me doing bad copy paste. It should be possible to extract the information from the dashboard on ASR.
sweetchaos
The Curator
BC, Canada
Digitized:
1. Audioholics / Arendal Sound 1723 Monitor
Missed one.
Also noticed that search is working strangely.
I search for LS50 and I only see 1 result, and it should be 3 (LS50, LS50 Meta, LS50 Wireless II).
Also, I finished compiling all USD prices into a spreadsheet...small progress.
P
pierre
Switzerland
Missed one.
Arc Acoustics
Japan
@pierre Thank you for your great work, which I should say at first.
But LW and ER of Revel Ultima2 Studio2 are wrong, resulting PIR and the score being better than the actual.
Please fix.
And, can I ask you to implement "Sort by the score with sub" and "Sort by the score with sub and Eq"?
That would show more interesting results.
sweetchaos
The Curator
BC, Canada
Errors:
Nexus MT DIY - not a center, but bookshelf?
LYX SPA8PAS - not passive, active
Elac Debut 2.0 A4.2 - blank graph
Revel W553L -in wall, not bookshelf
Vandersteen 2c - tower, not bookshelf
Polk Audio T50 - tower, not bookshelf
P
pierre
Switzerland
Errors:
Fixed except the Elac (too tired to understand what doesn't work)
Please fix.
Do you have better/correct data for the Revel? or I do not understand what's wrong.
I added the sort functions. It gives some funny results.
mtg90
Illinois
Errors:
The LYXSPA8PAS is passive, that's what the PAS suffix is for, the plain SPA8 model is the active one.
sweetchaos
The Curator
BC, Canada
Digitized:
1. Various\Grimani Systems Alpha Loudspeaker
2. Various\Grimani Systems Tau Loudspeaker
3. Various\Focal Alpha 50 Evo
4. Various\Mackie HR824
As usual...If anyone else finds a spinorama online, please let me know and I can digitize. :)
Error:
The image for Arendal Sound 1723 Monitor THX looks to be cutting out the top woofer. The current photo shows only 1 woofer, but it should be two. Link
Arc Acoustics
Japan
LW is shown as ER and vice versa.
PIR, SPDI, ERDI and the scores are affected obviously.
Thank you for the sort function.
ctrl
.de, DE, DEU
I don't see the mentioned sort functions
at https://pierreaubert.github.io/spinorama/
What's wrong with me or my browser?
P
pierre
Switzerland
Me neither, if I'm honest.
That's because I forgot to push the new code...
I fixed a few small issues, added the last speakers. Arendal Sound 1723 is still not working ...
I didn't check the EQ for the very special Grimani Alpha. The score is very low which looks strange to me, maybe because of the very constant directivity.
Pushing now and let's see what happens. It usually takes 10-30 minutes so don't jump on it yet.
Arc Acoustics
Japan
Thank you, and indeed the sort functions showed me very interesting results.
richard12511
I don't know, those Grimani Alpha measurements look not so great, especially for not being super high resolution, and the normal score for sure punishes for the lack of extension. It has very nice constant directivity, but a ton of resonances, and the overall slope is tilted up. The ER matching the LW and on axis above 10kHz is super interesting though.
thewas
