RandomEar
- Joined
- Feb 14, 2022
- Messages
- 337
- Likes
- 801
I'm currently planning to upgrade my 2.1 setup. I've done some research and am pretty sure what to get, but I could use some input on how to connect the sub. It has a line level mono input.
Current setup:
Planned upgrade:
I also thought about doing the stereo to mono downmixing using a miniDSP 2x4, or some ADAU1701-based board (e.g. Wondom APM2). I would expect that this excludes the possibility of crosstalk to a reasonable degree and would allow me to properly configure the downmix. But it also adds an additional A/D->D/A conversion step to the LFE channel. I'm open for ideas on how to (better) implement this route.
To state the obvious: Yes, the sub has speaker level inputs. I don't want to use those because of excessive cable routing. It also has a build-in low-pass and a single freq room-eq, which I currently use. But they could just as well be replaced by DSP filters, in case that improves other things.
I've looked at the following threads (and a couple more I don't remember):
Those were helpful to build the adapter, but didn't really answer my additional question(s).
Current setup:
- Rotel RA-12 (fed via S/PDIF from PC)
- ELAC BS 243 bookshelves
- ELAC SUB 2040 ESP (fed from RA-12 pre-out using self-build RCA stereo to mono adapter)
Planned upgrade:
- SMSL SU-9n (fed via USB from PC, with S/PDIF as fallback in case of a ground loop)
- Audiophonics MPA-S250NC XLR amp (fed from SU-9n XLR output)
- Same speakers
- Same sub (fed from SU-9n RCA output, using RCA stereo to mono adapter (?))
RCA Stereo to Mono converter where to buy ?
Was looking at merging Left,Right channels into Mono. I don't really want to build the adapter. Why are these so rare to buy ? Was looking at Amazon & Aliexpress but can't find much. for line out it would be this and with these adapters I could just ignore the soldering part. 'left + 1kohm'...
www.audiosciencereview.com
Resolved: Stereo to Mono Summing For Subwoofer
So I'm (mostly) retiring my Denon HEOS Link for a Topping E30. Unfortunately doing so has gotten me into a bit of a pickle. Currently, the Link has a Sub/LFE output that is summed in the digital domain. That LFE output is pumped into my single channel DSPeaker antimode and then finally to my...
Adding a subwoofer to a 2 channel DAC without adding an external crossover
I'm trying to add my subwoofer to my desk setup. I have an RME ADI-2 DAC. My subwoofer has only 1 XLR input available for use. Most hifi dacs/preamps only have stereo outputs. Only things like minidsp and some more expensive exotic units actually have dsp and multiple outputs. It's very rare to...
