NHT C3 Review (3-way speaker)
This is a review and detailed measurements of the NHT C3 3-way, sealed speaker. It was purchased new by a member and kindly drop shipped to me. It costs US $391 on Amazon for a single unit.
I must say, I was impressed by the fit and finish of the C3:
The enclosure is sold and dense with a beautiful piano black finish.
I love that the back panel has threaded screw holes to mount the speaker to the wall/ceiling for surround/Atmos applications:
Speaker is manufactured in China.
I performed over 1000 measurement which resulted in error rate of around 1%.
It is down to freezing outside so the best I could do was raise the temperature to 56 degrees. Speaker however was kept warm indoors prior to measurements.
Reference axis was that of the tweeter. Grills were not used.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
NHT C3 Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
EDIT: looks like the mid-range is damaged in this unit. It has a dimple on the bottom of it. This could explain the mid-frequency dip. Unfortunately I only have one unit to test so can't verify.
On-axis response is kind of wavy. This was unexpected as measurements performed elsewhere are much flatter. My in-room measurements showed the same so I don't think it is an issue with NFS measurements. Likely a design change was made to tilt up the highs more to keep up with the competition in the showroom. We can see the uneven response in individual driver response:
Seems like one could push up the tweeter level a bit or else, bring the tweeter down. The tweeter by itself has uneven response.
As noted in the first graph directivity is good so for good or bad, early window reflections follow on-axis irregularities:
NHT C3 Measurements Speaker Spinorama CEA-2034 Early Window Frequency Response.png
Predicted in-room response shows very little tilt so speaker is going to sound bright:
NHT C3 Measurements Speaker Spinorama CEA-2034 Predicted In-room Frequency Response.png
As I noted, directivity is good due to use of mid-range driver:
If you are going to use this up high for surround applications, be sure to tilt it down some:
Distortion was two completely different stories depending on level:
At 86 dB, this is professional monitor level of distortion, not a budget passive speaker! Push it though and things get bad especially with that tweeter. I have not seen one fall apart this badly. Fortunately that is where we have elevated response so we would want to EQ that down anyway and that should help keep that distortion in check.
Needless to say, at 94 dBSPL it exceeds our threshold:
Impedance is typical of these speakers, down to 4 ohm or so:
I forgot to mention earlier that sensitivity is rather low, dropping to 82 to 83 dB in mid-range area. Company advertises 87 dB which would only be true of the peaking tweeter.
NHT C3 Listening Tests and Equalization
The high frequency peaking was not obnoxious but clearly overdone (as appealing as that could be for a few seconds). So had to EQ that anyway and while there, might as well tweak the rest:
Filling that little but wide dip in upper bass was important in providing balance relative to highs (which I did not fully cure on purpose). I then filled in the 1 to 4 kHz region and job was done. Once there, the benefits of a sealed enclosure was there with its ability to play sub-bass without getting distorted. Alas, without the boosted upper bass that we get from ported speakers, the bass was a bit light but I was fine with that.
Dynamics was very good and speaker could handle a lot of power. And a lot of power is what I had to feed it so don't get a 50 watt amp. You need more than that.
It is a shame we didn't measure the C3 as well as others had. That would have made it a lot closer to ideal. As is, without EQ it is bright and hence "detailed." To my ears, that gets old fast so EQ is mandatory in my book. And so is filling in the other two dips. Speaker takes EQ well since we are not trying to push it where distortion is highest.
Overall, I was happy with the NHT C3 and would recommend it with EQ. No without.
  • NHT C3 Spinorama.zip
Doodski
Wowowow a 3 way speaker. Those are rare as hen's teeth these days. :D
cursive
Been looking forward to this one, thanks for taking the time to do it Amir. Also it saved me from having to send mine in, so thank you to whomever sent it!
I feel like I definitely hear the benefits of the sealed design in the bass as you pointed out, but is there any benefit to this unit being a 3 way, or is it more of a selling point and could be achieved with just two drivers?
dfuller
Doesn't look too bad! And, always nice to see sealed cabinets. I find them preferable at prices where big investment in R&D isn't feasible because ports always have problems if they aren't designed perfectly. .
Shoot, the owner noticed that in my picture the midrange is poked in on the bottom and it is!!! That could explain the worse than normal response in that region. I tried to see if I can poke it with my finger and I cannot. So it must have come that way. I will add a note to the review.
And one more thing :). The bubbles you see on the slanted sides of the speaker are not there. They are a reflection from my lightbox. The whole speaker is smooth, black piano finish.
txbdan
Interesting! I sent this one in to Amir as I have a pair of these on my desktop. I did a casual $300ish bookshelf shootout where I really liked the C1, but wanted more low end. That prompted me to up-budget a bit and get the C3s. The price fluctuates quite a bit on Amazon, I paid $322 each. The two standout qualities for me is the accurate low end and (don't shoot me) transparency. They sounded so natural to my ears. Finish and build quality is very good, too, they are tanks. That said, I do currently use Dirac Live to correct them :-D
FWIW, here's my measured room response. Interestingly it looks a bit more like soundstagenetwork's measurement than Amir's. Bump at 1.5-2kHz and dip around 5-7kHz. Of course the mess below 600Hz is my room. (The light colored line is the response, the dark flat line is Dirac's predicted response after correction)
Beave
Those midrange domes are incredibly fragile. The slightest touch can dent them. I know from experience with the previous version, the Classic Three. :facepalm:
cursive
I was going to say the same thing! I had the Classic Three as well which had an even smaller guard on them.
I have seen them able to be pulled out by sticking very mild/weak tape to the dent, and carefully pulling, but obviously that will be up the owner to decide how to proceed. It could easily be damaged with tape as well.
@txbdan I also have these on my desktop and love them! Thank you so much for sending one in.
Beave
The NHT C3 with the "carbon fiber" finish was measured by Soundstage at the NRC. Results here.
Note that the NRC measurement axis was between the midrange and tweeter, which could account for a *little* of the differences shown in the response in the midrange to lower treble.
That small dent in the midrange dome might also be contributing, but I wouldn't think it would make for such a broad dip over the driver's entire range.
I can't help but wonder if this is a unit-to-unit variation, possibly in crossover component tolerances, making the entire midrange output a little lower than it should be (as Amir notes in his plot of individual drivers).
Reactions: trl
Beave
I have seen them able to be pulled out by sticking very mild to the dent, and carefully pulling, but obviously that will be up the owner to decide how to proceed. It could easily be damaged with tape as well.
Yeah, when I bought my Classic Threes used, they had a tiny indentation. I tried to pull it out with tape and only made it worse with the slightest touch. Doh!
Oh. I almost did the same but then went with the tweeter. I can still manually recompute it.
Beave
It's crazy how much the distortion jumps up at the higher output measurement.
The sensitivity is low, and the impedance phase angles get pretty high (down to almost -50 degrees and up to almost +60 degrees).
Put all that together and these aren't speakers that are made to play super loud.
Beave
The three way here helps a lot with the consistently wide directivity in the upper midrange to low treble.
Beave
Ha, I saw that and was immediately puzzled, then I realized it had to be reflections. :)
Tks
That upper end distortion is worrisome. Question Marks trying to find how high it really goes was a nice touch lol.
ROOSKIE
Minneapolis
The Sound Stage measurements are pretty different.
I do wonder if damage exceeds just cosmetic. Maybe something interanl. That tweeter is just lost at 96db.
What is strange is that their HD test shows very low HD even at 96db@1m equivalent (they use 90db@2m) & no issue with the tweeter.
Was the speaker brand new or was it an Amazon Warehouse special?
YSC
That’s great eyesight! I didn’t thought that’s the surround originally! So it seems like some shipping problem?
As far as I know, new. Owner just arranged for an exchange. Once the other sample comes I will repeat the measurements.
