You need to include the full graph and notes:This is the purifi thd+n against frequency. Its superb.
As you see, the measurement bandwidth was 20 kHz. This means no harmonic distortion is captured at 20 kHz which is the reason it sinks so low. Even at 11 kHz no second harmonic is included since that would be at 22 kHz and hence filtered.
My measurements on the other hand go up to 45 kHz bandwidth so second harmonic of 20 kHz is captured. And for frequencies below 15 kHz, I capture third harmonic and so on.
Distortion then likely will rise at higher frequencies with Purifi.
