I use subtitles on almost every movie I watch.How many movies on average per year do you watch with subtitles?
...And with great care in their picture cinematography @ that.
Of course USED OPPO 203's are selling for $800+ on eBay and this review may push them over $1,000.
I own this player and for those who misunderstand it's purpose and benefits, let me explain:
Is there another multi analogue out player, past or present that's measured well? Other then the oppos of course. At one time this was not an unheard of feature, I'm more curious if there were versions with decent DACs in the normal realm, or if they're all more or less this until the oppo level.
UHD Player Audio Measurements
I played my 24-bit, 44.1 kHz 1 kHz tone used in my dashboard and this was the result:
Needless to say, I can't recommend the Panasonic DP-UB820 for analog audio output. Use your AVR's DAC over HDMI as it is likely to perform better.
No, the SINAD and THD+N is lower than 96 dB But the SNR is Higher than 96 dBYou are saying that "questions, comments, recommendations, etc. are welcome". Curious to see your reply. It seems that you, in fact, tested in a 16-bit mode. Are you sure there was no mistake in your test setup, either HW or SW??
It is part of the value proposition in this player to justify the much higher price than a bargain player. After all, if all you care about is digital transmission, might as well get a $150 player and be done with it. Dating back to SACD/DVD-A times, multichannel analog outputs in the player were supposed to be built to high standards given the pitch for the sources of that kind. As I noted this is one of the top 5 or so features highlighted by the company so it needs to deliver. Or don't put the analog out in there and advertise that it is great.
I've mostly avoided HDMI for the last decade. I used a server with Lynx AES16e out and Jriver. Eventually, I conceded because of the streaming devices I use and the need to decode the DD to my multi-channel system.What would it take to measure output from a test tone DVD, from the HDMI output? I don't really see any value in measuring a DVD player from a USB input.
