Paradigm Prestige 15B Review (bookshelf speaker)
Measurements agree with Soundstage/NRC save for the bass. Any idea what's going on ~100 Hz?
Yes, it is room mode in NRC's anechoic chamber. It has poor absorption when it comes to lower frequencies. My measurements are correct. :)
Billy Budapest
Energy is still producing speakers. I have not heard the latest line-up but I'm very familiar with the previous product and they where not bright sounding. Would be nice to see a Energy model tested here. :D
I think that Energy (and their related brands Mirage and Athena) were purchased by Klipsch. And if Klipsch did to them what they did to Jamo, know that all engineering is carried out by Klipsch in Indiana, the production is done in China, and although Klipsch has kept the brand name alive, that’s where the similarities between their older speakers and new ones end.
HooStat
Calabasas, CA
I found that the Paradigm Persona's that I listened to were really clear too -- that was my primary thought when I heard them (for about 2-3 songs). And I think if you listen 15 degrees off axis, which is not unusual if you face them straight instead of toeing them in, they are not as bright. Though I didn't look at the 15 degree measurements to check that.
Pdxwayne
Yup. Just need to adjust the toe in accordingly, based on distance and the room. I have found that my headphones can be much brighter than my Persona....
thewas
KEF’s tangerine waveguide thing also is stated to increase SPL by blocking part of the tweeter; still kinda confuses me.
A waveguide can increase the total SPL by improving the impedance matching to the surround air (some call that horn) but also can increase it for some angles while decreasing it for others thus increasing directivity which is rather the case when you block parts of it.
Chromatischism
Agree that these would definitely be an off-axis speaker. Point them straight ahead and sit in the middle of the triangle. At that point I'm sure they would be ok. Still, there are better buys in that price range and speaker size from Buchardt, Revel, and KEF, and I bet even the ELAC DBR's would put up a good fight at 1/3 the price.
Chromatischism
Right. I think the reference was to eliminating phase cancellations like a phase plug. I've never thought of that as improving SPL but merely the frequency response, but I suppose it could.
Chromatischism
Hmm, one would think their software could "see" that (or at least infer it from room dimensions) and calibrate it out.
Maiky76
French, living in China
Hi,
Here are some thoughts about the EQ...
The raw data with corrected ER and PIR:
Score no EQ: 4.48
With Sub: 6.73
Spinorama with no EQ:
  • HF too hot
  • some peaks in the 700 - 2000Hz range
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/15deg and have the axis crossing in front of the listening location, might help dosing the upper range.
The response will be much closer to the LW that is deigned for "flattish" in particular above 4000Hz.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
  • LW/Score pretty close so the decent directivity helps
  • HighPass filter added to help below 50Hz and maximize the performance within the bandwidth
Score EQ LW: 6.2
with sub: 8.4
Score EQ Score: 6.53
with sub: 8.73
Code:
Paradigm 15B APO EQ LW 96000Hz
January182021-143403
Preamp: -2 dB
Filter 1: ON PK Fc 49 Hz Gain 0 dB Q 1.15
Filter 2: ON PK Fc 177 Hz Gain -1.95 dB Q 1.43
Filter 3: ON PK Fc 865 Hz Gain -2.57 dB Q 3
Filter 4: ON PK Fc 1331 Hz Gain -3.16 dB Q 7.7
Filter 5: ON PK Fc 1873 Hz Gain 1 dB Q 2
Filter 6: ON PK Fc 6530 Hz Gain -1 dB Q 2.5
Filter 7: ON PK Fc 10657 Hz Gain -3.78 dB Q 1.4
Paradigm 15B APO EQ Score 96000Hz
January182021-142658
Preamp: -2 dB
Filter 1: ON HPQ Fc 48.5 Hz Gain 0 dB Q 1.15
Filter 2: ON PK Fc 174.5 Hz Gain -1.95 dB Q 1.33
Filter 3: ON PK Fc 857 Hz Gain -2.46 dB Q 2.55
Filter 4: ON PK Fc 1334 Hz Gain -2.18 dB Q 4.62
Filter 5: ON PK Fc 1710 Hz Gain 1.5 dB Q 2.21
Filter 6: ON PK Fc 5510 Hz Gain -1 dB Q 4.75
Filter 7: ON PK Fc 7436 Hz Gain -1 dB Q 2.72
Filter 8: ON PK Fc 11047 Hz Gain -4.12 dB Q 1.26
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
close to flat regression ON when EQ score is use
Radar no EQ vs EQ score
Large improvements
Bonus:
@amirm EQ
Score EQ LW: 5.57
with sub: 7.76
The rest of the plots is attached.
  • Paradigm 15B APO EQ LW 96000Hz.txt
  • Paradigm 15B APO EQ Score 96000Hz.txt
DuncanTodd
They certainly are good looking. I hope the review here from @amirm wakes them up and they stop making them so bright out of the box.
And yet people still buy Paradigm and Klipsch. Maybe not everyone likes flat response? It may be wrong according to studies, but the fact they sell well proves something. Of course you can argue people are ignorant or dazzled by showroom tricks, dealer discounts or general sheeping.
al2002
PSB? Stereophile and Soundstage measurements look respectable.
My analysis shows that the #1 speaker brand sold in all Canadian dealers/resellers is...Paradigm!
They are sold at 35% of all known resellers/dealers.
This is what we have to put up with?
I'm still waiting for at least one speaker from a Canadian company that's acceptable.
Mnyb
Sweden, Västerås
I think the shoowroom and the fact that most people including myself that tries to actually find accurate speakers to audition rarely succeeds .
I'm not sure I'm yet heard an god accurate speaker to this day after 30 years as an audiophile , been in the usual audiophile stores and heard what they presented to me as good speakers .
And you brain adjust (burn in anyone ;)) to the speaker and most people have only one set of good (or bad) speakers at the time and can do no side by comparison blind or sighted . you have your main set of speakers and adjust to them . But after a while you get an itch to upgrade and have a hard time to understand why. And go back to the hifi store where you audition more flawed speakers under flawed conditions :facepalm:
Vytauts
Lithuania
Hi,
Score no EQ: 4.48
With Sub: 6.73
  • HF too hot
Directivity:
EQ design:
Score EQ LW: 6.2
with sub: 8.4
with sub: 8.73
Code:
Preamp: -2 dB
Preamp: -2 dB
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Large improvements
Bonus:
@amirm EQ
Score EQ LW: 5.57
with sub: 7.76
Always pleasure to see your algo outputs. Thanks.
Was any speaker >7.0 EQ score?
DuncanTodd
Yeah, I agree with what you said.
Most of the people who still buy speakers (and not soundbars), would go by recognized brand name, friend recommendation, WAF, pushy dealers, showroom effect, price, sales etc. Most would be happy with them too cause as you said you get used to the sound. At the end most speaker companies want to sell as much as possible, and most folks don't care too much about how well the speakers conform to certain accepted scientific findings. "Correct" speakers would likely sound boring to them.
Dzhaughn
According to Paradigm, it is "Perforated Phase-Aligning (PPA™) Tweeter Lens that protects the delicate tweeter dome and acts as the Phase Plug, blocking out-of-phase frequencies for smoother, extended high frequencies with incredible detail and higher output. "
It would make a better shower head than the tweeter dome of any speaker reviewed thus far. Miles ahead in that respect. And $1500 does both bathrooms.
617
Somerville, MA
The Paradigms I've heard (reference signature?) with whiteish aluminum cones and aluminum waveguides sounded similar. The quality of the drivers they manufacture is absolutely first rate. The tweeter assembly is quite beautiful and the woofers with the phase plugs look nicer than anything from SEAS. It's a shame they don't make neutral speakers.
samwell7
Victoria, Australia
Perforated tweeter covers are in style.
Bowers & Wilkins for BMW and Volvo:
Burmester for Mercedes-Benz and Porsche:
Burmester-design-3D-rotating-tweeters-for-Mercedes-benz-C-Class-W205-GLC-X253-E-Class-W213-S-Class-W222-4-700x350.jpg
Lexicon for Genesis:
Those pictures remind me of some speakers I'd see in one of those party taxis somewhere in Thailand (only difference is the ones in the party bus would have LEDs behind them) no idea how that's supposed to be classy
