Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,237
- Likes
- 5,477
Why were you disappointed with the Solo6?
Should probably update my OP. On this day I had measured four speakers in one afternoon, so I had just posted the Solo6's measurements. It wasn't really bad, especially for it's intended application, but just not as good as I'd hoped for. I hoped it was more like the Sopra No1 in a cheaper package since it uses the same driver materials, but it measures quite worse than that.Why were you disappointed with the Solo6?
It would be indeed -- but, FWIW, I suspect (without data) that the delta in price will correlate (positively, that is) with a pretty marked delta in performance as well.Would be cool to see how Polk's new ES20 at $400/pair measures up and compares to the R200 at ~$700/pair.
I am also interested in the Reserve series, specifically the R700 floorstander and R400 center for my multi-channel system. Currently running Polk LS90 floorstanders (circa '93) in that system. Also have a pair of Monitor 7C (with RDO tweeters and crossover cap replacements) that I occasionally break out in one of my other systems.It would be indeed -- but, FWIW, I suspect (without data) that the delta in price will correlate (positively, that is) with a pretty marked delta in performance as well.
Many of the "value-priced" Polk products of the past decade or so seem to be pretty ordinary (although not bad for the $). The new L and R series seem to have the Polk brand (which, of course, is no longer Matt Polk et al's Polk Audio -- nowadays belonging to DEI Holdings/Sound United) back in the game as a purveyor of good sound in nice packages at reasonable prices. Whether they'll be perceived as such by the market at the price points remains -- I suspect -- to be seen.
That said, I am bullish on the "R Series" based on everything I've seen, heard & read. Bullish enough to be planning an investment in a pair (as I've already said ad nauseum).
I do wish Polk made a 3-way center in the Reserve series.
I am very curious to see how the 2-way R400 center measures on and off axis.
Interestingly, in previous 2-way centers, Polk often used a "Cascade Tapered Array" crossover (more like a 2.5-way) to reduce off axis lobing. For some reason, they've abandoned this crossover topology in most recent 2-way centers.
Some parenthetical comments:
Using a standard inflation calculator, the Reserve series pricing is in line with similar driver compliment models from the RTXXXi series from 20 years ago (for example, the RT35i standmounts and CS400i center). Looking at the engineering, technology, and performance of the R200, seems like Polk has upped their price-performance ratio with the Reserve series.
True, but a bit pricey at $1800, although it does have have phenomenal objective performance. It's also a couple inches wider than my set-up can handle.The Legend series uses a 3-way design, it would be a good match to the R700 towers since they use the same drivers.
Some more measurements to round things out. You want to be dead on with ear height on the R200:
So I finally got the R200 a week back. They go head to head with my Diamond 12.2, both have their own strengths and weaknesses. I like the Diamonds for having very smooth and buttery vocals, a deeper and more tactile bass when its called for and bigger soundstage width. The R200 are slightly better at clarity, better instrument separation and more thump in the lower regions. The Diamonds excel with higher powered amps, the R200 gets better but not as much. I have paired them with many amps, from the DA-9 to the Sony DH190 to my Onkyo reciever and to the best Ive got, the Rotel RC1572 MKII pre and RB 1552MKII power amp. The Diamonds sounded the best to me with the neutral Rotels, the R200 sounded better than the 12.2 with warmer and less powerful amps. Amp matching plays a part, regardless what some might say.
Both are one of the best speakers Ive owned, and considering the price, thats more than impressive. Im going to be keeping these 2 for a long time, a very very long time. They are that good. Ive owned way more expensive speakers and I dont like them as much. The OG LS50 is collecting dust. My next speaker, the Metas.
Hi Nanilopez. I always follow you posts with a lot of attention, but there is something really bugging me here...If you look carefully at the spin posts of All the speakers , you will notice they measure exactly the same on axis from 400 Hz to 1,5 Khz, to a t..The exact same wiggles with the same amplitude at the same frequencies, looking at it.
How can this be? Isn't this a problem with your measuring rig? I mean, they are very well engineered therefore should measure pretty much the same, but the same errors exactly at the same spots in so many different speakers looks like there is something being impinged on the results from an outer source, not the speakers themselves, or a big coincidence, what do you think.?
I usually sell off speakers that dont measure well, (that I bought without proper measurements) especially tonally, because I dont want to get used to sound that is coloured. If coloured sound become the norm for me, flat speakers would then sound like crap. Hope the R200 isnt far off flat, and I do not believe thats the case because it sounds flat to me, a little lean, but flat. Hope Amir does the R200, it would be interesting to see how different is it from Napilopez's charts. And now I can give up the idea of an aesthetically matching center channel for the R200. FML.Do we know if Amir will be reviewing the R200? I see he just did the R350 which isn’t a great performer as expected with that driver configuration.
A very general question.
The 200s appear to be similar to the 100s, only bigger and will therefore go a little deeper.
Now, let’s presume you were going to run these with a sub for deep bass, and let’s presume the sub can handle the bass frequencies which the 100 can’t handle but the 200 can.
In that case, is there any point spending the extra on the 200 over the 100, all else being equal?
I’ve asked this question in relation to these, but feel free to extrapolate to other brands and models.
