Polk Reserve R350 Review (Center Speaker)
Rate this speaker:
  • Poor (headless panther)
    Votes: 122 52.4%
  • Not terrible (postman panther)
    Votes: 98 42.1%
  • Fine (happy panther)
    Votes: 11 4.7%
  • Great (golfing panther)
    Votes: 2 0.9%
sarumbear
Coming late to this review and thread. Would it have been as simple as mounting the tweeter a few inches higher, or would the tweeter and midrange need to be on the same vertical axis to mitigate this off-axis cancellation?
(please take it easy - it's my first post after lurking for a few months :)
The latter.
Chromatischism
The latter.
Not exactly. There is always an off-axis cancellation with non-coaxial driver arrangements. Rotating the tweeter around another driver simply rotates the polar pattern and thus where the cancellation will occur.
Raise the tweeter enough and you can avoid it hitting the seats directly, but it will still be measured in the early reflections and sound power in the room.
aris3256
So where does this put you if you're looking for a center channel to pair with something like the R200's? I saw someone ask about whether the raised tweeter in the R400 center exempts it from the problems with the 350, but I never saw an answer to that; I'd also be interested in the (more affordable) R300. Given that both the R400 and the R300 are only 2-ways, I'm wondering whether something like the Monolith 365C would be a better pairing for the R200's?
Chromatischism
The Monolith 365C likely sounds different, and is sealed and meant for an 80 Hz subwoofer crossover ala THX.
I would try to match the capabilities of the speakers a little closer, especially in the bass extension/contour department.
Also, I still see the Infinity RC263 and Emotiva C2+ as better buys vs these purely-horizontal speakers like the Polk and JBLs reviewed here recently.
sword
There are many examples on AVS forum of mixing speaker brands in home theater with excellent results. Unless you listen to a lot of multi-channel music, the idea that all speakers must be the same or similar, or have the same "timbre", is an old tale that needs to die. Your AVR will handle different crossovers just fine. The 365C looks like a great option.
Chromatischism
Even when I use the same speaker it doesn't sound the same because the center speaker doesn't get the side-wall reflections that the L/R have. It is also pointed directly at me whereas the L/R are toed in for their best sound. If you've spent any time looking at Spinorama measurements you'll know that most speakers emit a different frequency response depending on the angle you're listening at.
Are these differences noticeable? They very much are to me, which is why I am in camp matching LCR, as much as is possible.
beaRA
The best match would be the Polk Legend L400, but it's rather expensive. The best affordable match is the Polk LSiM 706c while supplies last.
Transmaniacon
I wish Polk would release a R450 or something that employs a 3-way design like the L400. The R700 is a 3-way design, so they have the drivers to do it.
beaRA
I know, it's a bummer. Scott Orth let slip on a live stream that "no 3-way center" was a marketing limitation to differentiate the Legend line. I doubt we'll see an R450.
Transmaniacon
That's crappy, but I understand they have to incentivize the flagship series. If I had a home theater setup with the Reserve series, I would certainly try and stretch for the L400 as it would handle a majority of the dialogue.
aris3256
No love for the smaller R300? As luck would have it, that's what I ended up going with when I picked up the R200's. My thought was that the 5.25 woofers might be enough for an 18x20 room for an entry level home theater setup, although I'm sure the steep price difference between the two played a larger role than I'd like to admit.
beaRA
The R300 is still a 2-way MTM and the tweeter is not offset enough to get the midwoofers particularly close together. It will suffer the same narrow dispersion as every other 2-way MTM. I'm sure it sounds quite good directly on-axis though. If you can accommodate the size, the LSiM 706c is a much better buy at $400 right now.
Head_Unit
I simply don't understand how a speaker company can make such basic mistakes in engineering like this.
Just constraints from the marketing department.
I’m expect there were no engineers involved on the design. Marketing needed a narrow height speaker.
I think it's ridiculous Polk can't or won't do better.
It's not a basic engineering mistake. It is meeting the demands of the market, both the practical ("This is the only space I have for a center channel") and the ignorant ("A center channel should have woofers on each side of a tweeter, because almost every one I see is like that")/
- Yes, sometimes engineers have no say, latter-day Advent was a spec thrown over the wall from Sales and engineers just following that.
- But even sales/marketing are trying to get something sellable and 3-way costs significantly more.*
- I am certain Polk could do better, how much do you care to spend? It's all about DA BUDGET
*It will be interesting to see if the recent motion towards seriously larger tweeter waveguides and lower crossovers like on powered monitors will finally light a bulb in some home speaker person's head, whereby a horizontal Woofer-Tweeter-Woofer layout could have much better horizontal dispersion than the norm with little cost increase.
It would also be interesting if the old cone tweeters got revisited with modern materials, instead of domes. Not holding my breath.
Also not holding my breath for more-sensitive BMR drivers...
Chromatischism
Right. There's no getting around the physics of the space limitations. It forces the hand of the company. I would like to see a high-end speaker from Polk though that embraces a 3-way design like what Revel has done. It doesn't have to be quite as monstrous, but it's for those with dedicated systems that don't have furniture limitations.
Urvile
Seattle
They did it's the L400 I have one, and it's quite nice.
WeaponizedApe
Almost all do, it's been shown time and again, the best solution is a three way design for a center channel because of off axis response, though there are some two way designs that hold up fairly well off axis, but they are rare.
beagleman
Pittsburgh Pa
It is an intentional choice.
Same as asking why a $6,000 Revel tower is unable to produce a 28hz tone at any normal volume....
Think about it. Revel CHOSE to limit the low end of their towers. They could have made them go far lower, but CHOSE not to, due to size, maybe marketing demands and a few other reasons.
Same thing applies to center speakers.
Revel decided that MOST ( meaning maybe 90%) do not care if it can do 28hz well.
So, did Revel chose to limit their low end on their otherwise great speakers OR make a basic mistake in engineering?
Remember they could have easily found larger woofers that went far deeper .........so where did THEY go wrong...?
AudioScience Enthusiast
Since this is thread for R350, I have a question about my R350 that has some water damage.
Due to a crazy recent winter storm, the fireplace chimney had some bad water leak and some of it landed on top of the center speaker overnight.
Due to the duration of the water contact, some of the water stained the top cabinet finish and some of it made it into the edge between the top and back (because the speaker is slanted upwards towards the front using a pair of speaker stands). Now the edge between top and back is warped and appears wavy.
I can’t physically see if there is water that went inside through the port or how much the top cabinet has been penetrated.
Given this level of damage, do you think the structural integrity and the sound quality of the speaker has been compromised?
So far the sound seems ok but I haven’t stressed test it yet. Just wondering if it’s time to accept loss and use this chance to upgrade to R400
Beave
Where is the port on this speaker?
The water probably got underneath the vinyl wrap and into the MDF, which caused it to expand and maybe warp a little. It's probably a cosmetic issue only and not an audible one unless it caused enough warping to create a crack or hole in the MDF.
