Polk Signature Elite ES20 Review (Bookshelf Speaker)
Rate this speaker:
    Votes: 7 2.6%
    Votes: 36 13.1%
    Votes: 162 59.1%
    Votes: 69 25.2%
Thomas_A
Sweden
I wonder if the problem with the brightness is the HF or the 1-3 kHz dip?
Maiky76
French, living in China
This is a review and detailed measurements of the Polk Signature Elite ES20 bookshelf speaker. I purchased it from Amazon for US $349 a pair including shipping.
I really like the look and finish of this series from Polk. Despite budget pricing, it looks nice and purposeful as you can tell from the unique rear port plate:
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the tweeter center. No grill was used. Measurement temperature was about 62 degrees F (17 degrees C).
Polk ES20 Measurements
Let's start with our usual "spinorama" graph:
On axis is reasonably good, marred by some resonances between 600 and 1000 Hz. And some unevenness in high treble area. There is a directivity dip around 4 kHz.
I forgot to note on the graph the deep bass extension. F10 is at nearly 35 Hz! This is partly due to a cabinet that is deeper than normal.
We see the cause of that roughness around 600 Hz in our near-field measurements:
We see more of a dip in directivity caused in vertical axis mostly:
Fortunately my listening room has a thick carpet and high ceilings so I will be hearing a more optimal off-axis response than averaged above.
Predicted in-room response with my custom trend line is thus:
I usually draw the trend line after my listening tests are completed and do in a manner that is consistent with that experience. See the next section.
I was impressed by the smooth and constant horizontal beam width and dispersion:
This also has wider than usual response which should create a more diffused field around the speaker (my preference).
Vertically we have the usual restrictions but again, the sweet spot is larger than I normally see in this class:
I like the low distortion especially at 86 dBSPL:
But notice how that resonance around 600 Hz is also showing up here in the form of distortion. This means that we will have impact beyond that frequency due to harmonics.
We see the same resonance in impedance graph and waterfall:
Finally for fans of timing tests, here are the impulse and step response:
Polk ES20 Listening Tests
My female starting track which lacks bass sounding a bit muddy/tubby and somewhat bright. So I brought out the EQ tool:
First filter was around 600 Hz. It is a small filter but per past experience, it not only removed a bit of muddiness but also reduced distortion. The latter caused the sound to be more open and clear. Once there, on tracks with good bass, the sound was more or less balanced. But with female tracks without such, it sounded too bright to me. A quick and dirty shelving filter fixed that nicely.
Once there, I was extremely impressed with the fidelity. Track after track sounded beautiful. Not only was the tonality right but there was this clarity and lack of distortion that kept impressing me. ES20 could play pretty loud and distorted gracefully in that the woofer just lost deep bass and became a tubby. Pull back a bit and you were golden.
I can see Polk having to both want to create an accurate speaker while working within strict budget and retain channel that demands "showroom sound." To that end, they have done a very good job here, producing bass response that is way above what you expect. And do so with very little distortion. The only issue is the port/cabinet resonance which makes the sound muddy and screws up upper bass a bit. And elevated treble which can be a bit much if bass response is not there. Fortunately both of these factors are excess output meaning EQ not only fixes them, but also reduces distortion. Result is a speaker and sound that you can really be proud of.
I can recommend the Polk Signature Elite ES20 as is but hugely so with equalization. You are getting so much performance for so little money.
Hi,
Here is my take on the EQ.
Please report your finding positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 4.7
With Sub: 6.6
Spinorama with no EQ:
  • lots of resonances
  • not great directivity
  • Reasonably flat
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 5.3
with sub: 7.3
Score EQ Score: 5.9
with sub: 7.8
Code:
Polk ES200 APO EQ LW 96000Hz
May102022-182638
Preamp: -2.2 dB
Filter 1: ON HPQ Fc 44.80,    0.00,    1.20
Filter 2: ON PK Fc 113.09,    -0.90,    1.34
Filter 3: ON PK Fc 649.19,    -1.95,    4.75
Filter 4: ON PK Fc 1017.79,    -1.16,    4.85
Filter 5: ON PK Fc 2156.62,    1.81,    0.77
Filter 6: ON PK Fc 3535.42,    -1.47,    4.99
Filter 7: ON PK Fc 8574.03,    1.88,    4.87
Polk ES200 APO EQ Score 96000Hz
May102022-182432
Preamp: -2.7 dB
Filter 1: ON HPQ Fc 46.64,    0.00,    1.32
Filter 2: ON PK Fc 104.14,    -1.17,    0.95
Filter 3: ON PK Fc 637.31,    -3.23,    4.89
Filter 4: ON PK Fc 1012.22,    -1.88,    4.85
Filter 5: ON PK Fc 2155.62,    1.81,    0.67
Filter 6: ON PK Fc 3534.42,    -1.79,    4.99
Filter 7: ON PK Fc 6251.80,    -1.61,    0.75
Filter 8: ON PK Fc 8464.23,    2.20,    4.41
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Nice improvements
The rest of the plots is attached.
  • Polk ES200 APO EQ Score 96000Hz.txt
  • Polk ES200 APO EQ LW 96000Hz.txt
AudioSceptic
Northampton, UK
So many speakers have nasty upper mid resonances apparently caused by the port (can't speak of the boxes themselves buzzing along), yet others seem to avoid it. Got to say I wonder how this can be dealt with inexpensively?
No one seems to use the idea pioneered by Celef in the 70s, where the ports were filled with plastic drinking straws to provide resistance/damping for the air "slug" as it oscillates within the port. Or was that just a gimmick that didn't actually work?
GNK
ROK
Costs $218 for a pair in my country including VAT. Looks like a very good speaker in its price if not considering its big size.
thewas
That works, have seen it done in some DIY loudspeakers, probably not just very practical, robust and beautiful for an industrial product. As said nowadays there are also more elegant ways to reduce those problems.
Shadrach
Hi,
Score no EQ: 4.7
With Sub: 6.6
  • Reasonably flat
Directivity:
View attachment 205827View attachment 205820
EQ design:
Score EQ LW: 5.3
with sub: 7.3
Score EQ Score: 5.9
with sub: 7.8
Code:
May102022-182638
Preamp: -2.2 dB
May102022-182432
Preamp: -2.7 dB
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Nice improvements
Can you explain to me why this should have a higher preference rating to the KRK linked to below?
Matias
São Paulo, Brazil
A shame about the port resonance as everything else looks great. I voted "Fine" just because of that, even considering the price.
Transmaniacon
Good sounding speaker! I am loving my Polk R200s, glad to see their more budget options still performing very well.
DSJR
Suffolk Coastal, UK
Mission used this 'drinking straw technique' too and it definitely reduced the 'chuffing noises' of an undamped port tube. Other makers use foam lining to reduce turbulence, but so far, I haven't read anything about acknowledging the upper mid resonances so many ports add, let alone dealing with them. maybe the foam or drinking straws deal with this quite easily?
beagleman
Pittsburgh Pa
KEF addressed this, with a flexible portion in the middle of the port.
I think it varies a lot also, just based on factors that are not easily modified.
I read once that it is a "Partial" trade off of losing some bass response, versus a pipe resonance being somewhat higher in magnitude.
One of those things, that just come with the territory of vented speakers, but it can be varied but never eliminated based on the actual tube (Vent) resonating at some frequency.
I am not sure, but I also have heard the proliferation of smallish speakers with small vents, causes a lot of this issue. Larger boxes and larger vents do not suffer as much...
DSJR
Suffolk Coastal, UK
He says he has "NO IDEA" what that cover does.
Without it, the port would be flat against a wall and blocked....was it that hard to imagine?
Maybe some tube connectors would fix that....:facepalm:
Got to respond in kind - I couldn't really see anything wrong with the crossover either - poly cap where necessary, air coils which I 'm sure are fine for the power handling, resistors the same and one electrolytic which again, should be fine for a ten plus year life and the extra resistance must be part of the crossover tuning?
beagleman
Pittsburgh Pa
Polk also had a "Cure" for the port issues, on several other models, they would have a front AND rear facing port(s) of different diameters, but tuned to the same Bass box frequency, supposedly the rear and front radiation, along with the different sized ports would reduce this issue.
Glitch
Queens, NY
Will using a curved pipe reduce higher mode port resonances?
What causes the resonances, is it more the port or the cabinet?
MZKM
Land O’ Lakes, FL
See my last graph breaking down the score components, the SM_PIR is low, this is because it is a constant directivity design (as are many studio monitors), As such the off-axis in the treble shelves down instead of sloping down. This can lead to a bright sound when used in a living room sized setup; I do not know whether it is the best idea or not for studio use (Mr. Sprinkle designed JBL monitors with constant directivity but when he moved to Kali he did away with it and claimed doing so sounded better).
Also note that the score is not super valid for studio monitor use, as that is in the near/mid field, whereas the research was only done in far-field.
Hipster Doofus
Hi all
as I always mention I an not a stero numbers guy but love good stuff. These reviews allow me to pick up knowledge and also get to the bottom line.
my thought today is home theater speakers, I have 3 listening rooms with good speakers for music and one happens to have my tv and Denon 960 in it. I run audyssey and all that but….
These Polks beg the following questions.( for just tv and movies)
1. what and where is the baseline and parameters for home theater surround? Some basics goals so to speak. We all like to upgrade and this area seems to be the easiest/cheapest and lots of fun as well.
2. Is it better to have the fronts and backs speakers be the same model number? talking 5.1 here.
3 is 7.1 really better then 5.1 and if so in what size room does it matter.
4 as with many speakers reviewed here they are great with that little eq tweak, can our audyssey do that vs Roon?
5. could there be a rating chart as there is for dacs, and amps and head phones or even an asterisk *
anyway hope this give us something to chew on
thanks in advance.
Shadrach
Thank you.
I did wonder how much influence listening distance had on the score.
I really need to take some time to properly understand how the preference score works.
Thanks again.
MZKM
Land O’ Lakes, FL
It's 4 components, I'll explain them without getting into the actual calculations:
  1. Narrow Band Deviations of On-axis: Chunks the response into sections, averages the SPL of each section, within each section it sees how the SPL of the individual frequencies compares to the section average.
  2. Narrow Band Deviations of PIR: Same as above but for the PIR.
  3. (aka correlation squared) of PIR: Checks for a linear relationship (trend line) for the PIR; downside is wide vs narrow dispersion plays a role, where more slope (narrower dispersion) scores higher.
  4. Bass Extension: Self explanatory
While we don't have the 70 spinoramas & human response data, I'm willing to bet that if Olive just "normalized" the PIR to its own slope and did the PIR on that, that the preference rating would be more accurate. The reason to have #3 is that since the PIR most always has a slope, #2 won't score super high, as the avg SPL of the treble would be lower than the avg SPL of the midrange, so #3 is added to the formula to offset that (greater slope: lower NBD & higher SM ; lesser slope: higher NBD & lower SM), but the offset isn't great as it seems #3 changes more than #2 does.
