I didn't read about what exact instrument device was used for the testing. I read the review. I don't understand the tool, conditions, or logic behind the test. I'm not embarrassed. A good explanation of the instrumentation and methods for this test would be beneficial... Also was the instrument properly calibrated and if so by what method.
undue skepticism of the testing equipment or the tester shows how hard it is for humans to shift their beliefs in the face of evidence.
If you read a bit more of the forum you will find that info.
Amir has been doing this for a while. And has a standard procedure etc. And knows what he is doing. If he had to re-explain every facet and the significance/reason for each test at every review, it would be far too cumbersome. He does not need to write a 40 page paper for every amp tested.
Anyway, how detailed do you want? Either you have high expertise in the field of audio measurement so as to understand even more highly technical details, or you don’t and they won’t help much.
