- Joined
- Feb 23, 2016
- Messages
- 20,771
- Likes
- 37,635
What I have in mind is something similar to Spurious Free Dynamic Range. You have maximum signal and any other signal whether noise, harmonic or intermod distortion or jitter spurs or idle tones or aliasing or anything that should not be there with the signal.
I would propose the clear to -100 db group, to -110 db group, and if we get any, the clear to -120 db group. Anything less than a 100 db of free and clear range these days should be considered a fail.
The only thing I can think of that wouldn't show up here is some linearity errors. Those would only occur with multi-bit DACs and a note could be attached to the results of those.
Now there are features and other things worth considering, but perhaps this would allow us to group DACs by basic performance to narrow the field some and make it simple for non-techies. All such simplifications have problems and leave out details. The question is whether it is helpful short hand, and what it leaves out is less important than what it gets right.
I'll post a proposed way of viewing these in the next few posts using spectrograms.
