PS Audio Noise Harvester AC Cleaner Review
pozz
Слава Україні
Editor
Other AC cleaner to review:
iFi AC iPurifier
https://ifi-audio.com/products/ac-ipurifier/
-> [PDF] https://ifi-audio.com/wp-content/uploads/2019/07/TECH-NOTE-iFi-PowerStation.pdf
The problem is the passive filtration graph... misleading advertising the least. At 10 kHz there are RF/EMI passive filters with much better numbers than this active filtration. With measurements. And... cheaper!!!
Look up Filter (AC) and enable all review types here, which gives you: https://www.audiosciencereview.com/...ts-of-schiit-yggdrasil-v2-dac.3607/post-87027
GXAlan
The other company with as much audiophile-claims-without-data is AudioQuest. Good thing Amir has one of their “budget” line conditioners for testing too. :)
AudioSceptic
Northampton, UK
I would love for anyone that can measure audio equipment to see if you can get a device to measure worst by plugging in household equipment in the same socket as the audio device. For example, plug a DAC and a microwave into a power strip. Can a microwave mess up performance? Maybe a fridge, a powerline ethernet adapter? Is it even remotely possible in a worst case scenario that power gets so bad you can see the effects in a measurement?
I have heard that devices using SMPS often put noise into the mains, enough to affect the performance of other audio devices. Does anyone have any evidence of this?
garbulky
1. Why do your ac mains carry so much distortion?
2. Why do ac mains in general do so?
3. Does your lab powered AC supply do any better?
YSC
I never understand that why anyone would believe in these sort of plug it in one socket and it will cleans up the whole house thing
ta240
well, you have to buy a bunch of them and plug them into more than one socket ;)
Someone asked Paul why he didn't build those into his amplifiers and his reply danced around it with saying that some people don't like the flashing light.... because there is no way to cover it inside a component or use something else to dissipate the built up energy I guess.
Like many of his claims it is a neat idea that sounds really impressive and has a tiny bit of it founded in science but as a whole it doesn't do anything.
eycatcher
Is it possible to look at clock phase noise and jitter with and without the harvester to see if there is any relation with power to those measuements?
AndrewDavis
If the LED doesn't dissapate enough power could we hook this up to a Tesla coil, or some other type of device? I would love an amp that periodically zaps and sparks- like something in Dr. Frankenstein's lab.
617
Somerville, MA
"A lot of tweaks sold to audiophiles make claims that follow the laws of another universe so we can't use our tools in this universe to test them. " This is the essential problem with PS Audio; they try to maintain a respectable facade but this just makes them the target of ridicule. Nobody bothers the crazies who completely own it.
3125b
Germany
They should be making one to "protect" people from 5G and whatnot. Thats a much bigger market :)
Plus development costs are low, they just need another print on it.
dmac6419
USofA
This is a review and detailed measurements of the PS Audio Noise Harvester and AC Cleaner. It is on kind loan from a member and sells for $99.
The harvester is a bit bigger and uglier than typical phone charger:
Claim to fame is that AC noise is captured gradually and then discharged all of a sudden into the LED on the right to get rid of it:
One wonders why a sudden discharge wouldn't be bad for your sound versus a gradual/constant thing!
As to discharging "all the unwanted noise" company shows no specifications or measurements to demonstrate that. It is trivial to measure noise so not do that?
Also, I see no indication of safety regulation on the device and on the website. It is one thing to lack such marks for low voltage devices but an entirely different matter when you plug something in to mains and leave it there. A safety flaws could lead to fire or worse. What would this thing do for example if a powerful external surge arrives? Does it open up gracefully or short and cause smoke?
Does It Do Anything?
A lot of tweaks sold to audiophiles make claims that follow the laws of another universe so we can't use our tools in this universe to test them. Here though, we can. AC mains is at 50 or 60 Hz. A filter better not touch these frequencies or you would loose the very energy you need for our device to function! As a result, filtering will be at some higher frequency, often well above hearing range making them useless for improving audio.
To determine the filter range, I set my Audio Precision to produce 21 volts output and captured and plotted that using very wideband response (1 MHz). I then inserted the Harvester in the middle to see the effect:
Hey! There is some good news here. There is filtering that occurs in the audio band and indeed, we have reduction of frequencies above 500 Hz with best response (naturally) at higher frequencies. There is a resonance causing that peaking but otherwise, we have about 20 dB of reduction. The harvester was blinking away happily saying it was doing its job.
Would this do us some good? Well, let's look at the spectrum of AC in the power strip that I use to power my analyzer, the PC and anything I review. To not kill myself or the analyzer, I used a simple AC transformer to bring the voltage down. Otherwise everything is the same:
In blue is the spectrum of the AC mains. Instead of the ideal single 60 Hz tone, we have a myriad of other tones. Highest peak is nearly -30 dB. This result in a THD+N of nearly 3%.
Once I plug in the Harvester, we get the graph in red. Yes, it almost looks identical because as I showed before, it doesn't do anything below 500 Hz. Unfortunately that spectrum between 60 and 500 Hz has most of our distortion and noise. What is above that has far lower amplitude.
Even in high frequencies we don't get much attenuation because the amount of energy harvested and dissipated by this box is too little. Imagine what it takes to power an LED for a fraction of a second. It is probably in microamps which would mean nothing in grand scheme of things. No wonder then that THD+N doesn't change (the number varies fair bit so don't focus on decimal places).
In addition to frequency domain, we can also look at the waveform in "time domain:"
We can easily see the effects of 3% distortion in how the tops of the sine wave are distorted (flattened mostly). Sadly, the Harvester does nothing to turn our ugly sine waves into pretty ones. With or without, the shape is the same.
At this point we have fully characterized the device. It is a low pass filter with very negligible effectiveness. But maybe it performs some magic that escapes these measurements but shows up in audio devices so let's test them with and without the Harvester.
AC Cleaner Effect on Audio Performance
Let's start with the most sensitive and highest performance "audio" device I have which is my Audio Precision APx555 analyzer. I put it in the loopback mode and measured its own distortion+noise over time. After a bit of time, I plugged in the Harvester and then took it out. This is the results:
As you see, it made no difference whatsoever even though we are measuring distortion and noise that is whopping -123.5 dB below full level! Why doesn't it care? Because it designed with the assumption that AC mains is never clean or remotely so. All the necessary filtering is performed internally which is a lot easier when dealing with low voltage DC, than high voltage mains AC.
OK, so that is a $28,000 analyzer so let's step down to a much more reasonable $500 Topping A90 which I recently reviewed:
The harvester blinking away saying it is doing something. But again, in super sensitive measurements representing far lower threshold than our hearing, there is no effect on noise+distortion at all.
Let's go even cheaper to $99 JDS Labs Atom DAC:
We can see how sensitive our measurement system is in detecting very small variations in performance of Atom DAC. Clearly there is some "noise" there to clean up but the Harvester does nothing for us.
Maybe we shouldn't use high-performance audio devices. For that, let's use the Schiit Modi 2 Uber DAC:
Not... one... thing... different! Surely the Harvester should have gotten lucky by now and did something. But it did not.
Listening Tests
Folks always come back and say "but I hear a difference, you should use your ears." So that is what I did. On the same computer used for above, I use an RME ADI-2 DAC V2. Into that I use an Ether CX headphone. I plugged in and unplugged the Harvester multiple times but could not detect any difference whatsoever.
If you are hearing a difference, turn away from your power strip, have a loved one plug the device in and out at random times and have you raise your hand when you think it is plugged in. After just a minute or two, you will get the right answer which is there is no audible difference. Your brain concludes that there is less noise because you are told there is less noise with this device and hence you "hear it." Lack of change in audio waveform reaching your ears be damned.
In some sense it is a relief to find an audio tweak that we can analyzer and characterize what it does. It indeed filters "some noise." That filter is too small to begin with. But importantly is of no use because your good audio devices already filter that noise. Imagine how bad my audio system would sound if the 3% harmonic distortion and noise was let through! Which designer you cherish would sell you an audio device that doesn't do such filtering when it is so easy and cheap to do???
Remember, the company could easily measure noise and show the improvement with their own or other companies' products. But they have not. You wouldn't take a drug with no verification of its efficacy. Why would you trust a company to sell you something to "clean your AC" where no such evidence is not at all?
On top of that, you have a mains operated device which no third-party verification that is safe to be plugged in. As such, it is illegal to sell in probably every western countries if not others.
Be a smart audiophile. Don't put your guard down just because there are positive testimonials for such devices. I don't care how useless an audio device is. Some people will say it performs miracle. These people don't know how to perform a simple, bias controlled test to verify the truth. Don't listen to them. Don't put your guard down.
And before you say everyone who owns one likes it, watch this:
June is turning out to be an expensive month. I will probably be close to shipping back 500 pounds of gear and have spent nearly $1,500 on gear. I can afford it but will feel entirely more positive if you all donate it! https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Is that 99 cents or 99 dollar
solderdude
The Neitherlands
The 'top' is flattened because almost all electronic devices ONLY draw currents on the tops.
Lightbulbs, heaters (unless when they switch on/off by a thermostat) usually draw current continuously.
There are hundeds of devices in parallel on the mains grid.
For above reasons. Do note that relatively 110V systems are affected more than 230V because the currents are lower at the same drawn power.
That would depend on HOW the output is generated. There are several ways to do it.
Do note that the harmonic spray isn't really problematic with audio equipment because all incoming AC is rectified and often regulated afterwards.
A bigger problem could be common mode currents and HF 'garbage' on the mains in certain cases.
Vini darko
Dorset England
I have cd player with a dodgy transformer that affects some of my other equipment. Even if it's plugged into a different room. Suffice to say I don't use it much.
Vini darko
Dorset England
There's definitely a market opportunity for clothes claiming to containing a Faraday cage. I wonder which companies will start selling Faraday hats first?
blueone
USA
If you really think the AC source is noisy and believe it's affecting your equipment, why not just use an isolation transformer? A couple of decades ago when I lived in San Diego, and my reel-to-reel tape deck and FM tuner seemed noisy for no reason, I tried a transformer and the noise was cured. In every other place I've lived no issues at all, and the transformer sits in a closet. The Harvester looks like a device specifically meant to dig a hole in your wallet. Not as bad as a Tice Clock, but up there.
3125b
Germany
Newk Yuler
Some years back I participated in a discussion concerning the Noise Harvester at PS Audio with Paul McGowan participating. I'm not certain, it may have been an email discussion while I was thinking about buying one. It was promoted as being obviously beneficial to any audio hardware plugged into it. So I asked Paul if it cost so little and everything benefited from its use why he didn't put the circuit behind the power input of all their equipment so everything they made would have an obvious performance edge. He didn't reply to the question. I didn't buy one.
