RCF AYRA PRO5 Review (Powered Monitor)
Rate this speaker:
    Votes: 13 6.5%
    Votes: 89 44.7%
    Votes: 90 45.2%
    Votes: 7 3.5%
This is a review and detailed measurements of the RCF AYRA PRO 5 powered studio monitor (speaker). I purchased this new from Amazon for US $149 (each) including shipping.
The PRO5 looks serious enough although a bit busy for my taste. Like the waveguide for the tweeter which should make for more controlled directivity.
RCF AYRA PR05 Review Back Panel XLR Studio Powered Studio Monitor Budget.jpg
You have the standard controls here. It is bi-amped with dual class D amps (45 and 25 watts). My room is a bit noisy for this type of test but I put my ear close to the tweeter and I could barely hear a hiss.
Company advertises FIR filters and DSP correction.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the center of the tweeter (aligned by eye). Measurement room was at 10 degrees C which may lower bass output a bit. Accuracy is better than 1% which is quite good.
RCF PRO5 Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
RCF AYRA PR05 Measurements Frequency Response Powered Studio Monitor Budget.png
The on-axis response is fairly irregular and we see many resonances as we approach 1 kHz. Near-field measurements indicate that it is the cabinet/port that is resonating:
RCF AYRA PR05 Measurements Near-field Frequency Response Powered Studio Monitor Budget.png
Being front-ported means that these resonances would be more audible than they would be otherwise.
Directivity is good which means flaws in on-axis response also translate to off-axis:
RCF AYRA PR05 Measurements Early Window Frequency Response Powered Studio Monitor Budget.png
Predicted in-room response as a result is not very pretty:
RCF AYRA PR05 Measurements Predicted in-room Frequency Response Powered Studio Monitor Budget.png
The port/cabinet resonances are causing coloration in upper bass and midrange. The trough will impact openness of the sound in lower treble. On the other hand, bass extension is quite good with flat response down to 60 Hz! Likely it is enjoying DSP correction given the sharp drop below that.
Beam width measurement shows delightfully smooth and even response in horizontal axis:
RCF AYRA PR05 Measurements Horizontal Beam width Powered Studio Monitor Budget.png
RCF AYRA PR05 Measurements Horizontal Directivity Powered Studio Monitor Budget.png
Vertical is not very pretty but that is typical of 2-way speakers:
RCF AYRA PR05 Measurements Vertical Directivity Powered Studio Monitor Budget.png
Distortion is kept in check at 86 dbSPL with the exception of a pronounced resonance:
RCF AYRA PR05 Measurements Relative Distortion Response Powered Studio Monitor Budget.png
RCF AYRA PR05 Measurements Distortion Response Powered Studio Monitor Budget.png
Waterfall display shows the resonances we have seen in other graphs:
Here are the impulse and step response for those of you interested in that:
RCF AYRA PR05 Measurements Impulse Response Powered Studio Monitor Budget.png
RCF AYRA PRO5 Listening Tests & EQ
I was not fond of the out of box sound although it was not terrible. So brought out the EQ tool and applied some broad, macro-level corrections:
After listening with EQ on for a few minutes, going back clearly showed the problems with stock response. Upper bass is exaggerated and midrange is colored. With EQ, this was very acceptable response especially when one considers the price of this speaker.
Power handling was excellent. Bass deep was there (relative to the size of this speaker) and as you turned it up, speaker gradually limited the output. It avoided cracking or any other odd response. Just wouldn't keep getting much louder.
RCF gets a lot of things right here with nice directivity, power handling and design, bass output, etc. The one thing they left to chance is port/cabinet resonances. If that was not there, this would have been one remarkable speaker. Fortunately such resonances have a rather mild effect and EQ was effective against them. Once there, I was pleased with the performance of the speaker and dynamic capabilities. You are getting two amps, DSP and two DACs and a speaker for just $149. Lots of value here.
I am going to assume that you will be applying EQ to this speaker and as such, I can recommend it.
EDIT: Video Review Posted:
  • RCF AYRA PRO 5.zip
martijn86
The Netherlands
I'd be interested to see if it cleans up when you plug the port(s) and use the +2dB low frequency trim switch for example.
voodooless
Netherlands
I expected a little bit more out of this, especially time alignment wise one would expect to see the profit of the FIR filters. Not so much, except the impulse response looks neet. The good thing though is that the measurements basically match those of the spec sheet:
Curiously, all speakers of this series have the midrange dip. It must be a design feature.
Vict0r
The Netherlands
Can resonances be countered with structural reinforcement or dampening?
voodooless
Netherlands
Basically, if you know where it's coming from, you can probably fix it.
tomtoo
Germany
But a strange design decission for a studio monitor?
voodooless
Netherlands
You would think so. But standing out might be the motive here?
Would love to see one of those new ART 2-way's tested. They also have FIR filtering, but are quite a bit more powerful. For instance the 10" version. Frequency response is also smoother, though still has some V-shape:
They also seem to have some active bass control, which should be very interesting to see in action. At € 499,-, not even very expensive. You can't even get a plate amp with that kind of power for that money.
LearningToSmile
The resonances are a bit disappointing, I doubt they'd be gone in the 8 inch version. The more reviews of monitors in this class I see, the better my decision to buy the JBL308's looks in retrospection.
Maiky76
French, living in China
Hi,
Here is my take on the EQ.
Please report your finding positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 3.7
With Sub: 6.0
Spinorama with no EQ:
  • lots of resonances
  • LF seems good
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Code:
RCF AYRA PRO 5 APO EQ LW 96000Hz
March172022-161333
Preamp: -2.7 dB
Filter 1: ON PK Fc 182.92,    0.98,    2.35
Filter 2: ON PK Fc 323.38,    -1.55,    3.88
Filter 3: ON PK Fc 541.20,    -3.41,    2.07
Filter 4: ON PK Fc 749.49,    -1.40,    4.95
Filter 5: ON PK Fc 964.42,    -1.81,    4.96
Filter 6: ON PK Fc 1369.21,    -4.65,    4.85
Filter 7: ON PK Fc 1614.30,    3.97,    1.74
Filter 8: ON PK Fc 3191.71,    -1.20,    2.51
Filter 9: ON PK Fc 10821.22,    -1.88,    1.17
RCF AYRA PRO 5 APO EQ Score 96000Hz
March172022-160731
Preamp: -2.7 dB
Filter 1: ON PK Fc 175.60,    1.47,    3.49
Filter 2: ON PK Fc 327.14,    -1.55,    2.88
Filter 3: ON PK Fc 540.20,    -3.26,    2.07
Filter 4: ON PK Fc 763.12,    -1.90,    4.95
Filter 5: ON PK Fc 967.42,    -1.81,    4.96
Filter 6: ON PK Fc 1385.91,    -4.53,    4.60
Filter 7: ON PK Fc 1699.91,    3.97,    1.74
Filter 8: ON PK Fc 3185.01,    -1.78,    2.26
Filter 9: ON PK Fc 10852.06,    -2.81,    0.84
Score EQ LW: 5.2
with sub: 7.6
Score EQ Score: 5.7
with sub: 7.9
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Great improvements
The rest of the plots is attached.
  • RCF AYRA PRO 5 APO EQ Score 96000Hz.txt
  • RCF AYRA PRO 5 APO EQ LW 96000Hz.txt
I did plug the port. And it did clean up but then I lost so much bass. Was hard to know if that was a good trade off. Leaving the port and applying EQ let me have my cake and eat it too! :)
Thanks Amir!
Nice to see a new speaker review. It had been a long time and I'm so addicted.
It has been. I had so much stuff piled where the NFS is for our flooding project that I could not use the system. Finally cleaned it up and am back to business!
With DSP, they should have been able to correct the response anomalies themselves, shouldn't they ?
I think so but it is possible they don't have the precision measurements we have that show the flaws. Their own measurements are highly smoothed.
Dennis_FL
Venice, FL
Looks like an Audyssey Midrange Dip.
PeteL
Slightly unimpressed by these measurements. Of course they are very cheap speakers and for that money it's hard to ask for much, I haven't heard them but I was hearing a lot of praise left right and center for those from people. I was expecting Adam T series performance or close. I don't see that.
