Recommendation: Programmable Linear Power Supply
c1ferrari
Hi all,
I'm in the market for one of these...either new or pre-owned...preferrably 3 ch...1.5k max budget.
Thanks.
Hehe -- I almost left intact Poser rather than Power in the subject field
. o_O
The Rigol DP800 series is the go-to brand for engineers/hobbyists these days: https://www.rigolna.com/products/dc-power-loads/dp800/
The prices are quite reasonable in $500 to $800 range.
There were some design issues in the first generation model (heatsink too small on one regulator) so don't get a used one.
The down sides are fan noise, and very deep enclosure.
I don't have one though so no personal experience.
c1ferrari
c1ferrari
Thanks, Amir -- I saw a version of this on EEVblog when he was recharging a Li-ion battery. The price is right! I think I'd rather the color version, though.
c1ferrari
c1ferrari
The color version is harder to use because it puts the three settings for each voltage on a circle! So you can't easily associate which is which with respect to the outputs. They do have a firmware update to make it look like the green one with three vertical bars and there is a youtube on doing the upgrade. However, I heard that they may give you a hard time in giving you that firmware.
I'll take a look...thanks. Would you be aware of any Keithley power supplies that merit attention?
Keithley stuff is also highend like Keysight so I would not hesitate to use their products.
c1ferrari
c1ferrari
Yes, the polar-type display should give way to the three columns -- but, in color! :cool:
c1ferrari
c1ferrari
I don't think Keithley garners the respect their products warrant.
Rohde & Schwarz and Hameg may be worth it ($$$), too! :D
My UPV needs a companion. :p
c1ferrari
c1ferrari
It does stay in color with the new firmware. Here is the video that that I was talking about regarding the update. It shows the color screen at the end:
Some good vids on this Rigol, but -- GEEZ! :confused:
Color 'Classic' display has nice appearance.
DonH56
Monument, CO
I tend to like the ones that have a button to shut down the display -- it tends to radiate noise that your cables can pick up even if it does not appear directly on the outputs. I have never used a Rigol so cannot comment but Keithley and Keysight make some really good models. There are also a number of programmable models by companies like Lambda and others that are more basic but offer good performance and some sort of serial or parallel cable (UART/RS-232/GPIB) program capability. Do check noise specs if you want a truly low-noise model, and expect to pay for it. Or build a filter of your own, usually a cheaper way. Also be wise to invest in an isolation transformer if using it for measurement purposes, but be aware higher-frequency noise will find a way and the CMRR of most devices falls off rapidly with frequency.
Man, that is one cool cat! :D I am tempted and I don't even need one!!! :D :D
They have combined their 6.5 digit meters with a power supply. Very nice idea. Then 10 na range for current is also very useful.
Get it, then send it to me to measure the Uptone ISO Regen with it. :)
c1ferrari
c1ferrari
If I purchase it, Amir, I'll send it up. :cool:
Whom would you patronize for purchase?
Tequipment.net is the usual place for test gear. I went there though and it says both versions of this supply are discontinued! http://www.tequipment.net/Keithley/2280S-60-3/
Alternatively I buy through Amazon and they are stocking one unit. I would further investigate if the unit is discontinued.
c1ferrari
c1ferrari
Wow...first I've heard of the 2280 series being d/c'd. :eek: It appears available elsewhere, however.
The 2280S-32-6 is listed as a current product on Keithley's w/s.
It is a recent product so surprising to see that. TEquipment guys are pretty good on chat. Engage them on Monday and see what the beef is and their best price. They have a discount for EEVblog members too and so just ask them about it.
BTW, be sure the max voltage and current meet your needs.
c1ferrari
c1ferrari
Thanks, Amir. "Chat" via TEquipment w/s will have to compete with my students and the solar eclipse this Monday! :D
The only other 2800-series instrument is the 2280S-60-3. Which would you get?
