GM3
- Joined
- Nov 26, 2022
- Messages
- 142
- Likes
- 164
Just to be clear, is this something which can be affirmed, or just a possibility?when I say I suggest they optimzied it for the ASR protocoll I mean that the whole product is designed like that
I'm not technically literate enough to be certain, but the way I interpreted the situation, it could also simply be that Amir's test procedures could be said to be somewhat incomplete, and fail to detect issues under certain conditions, ex; given particular speaker loads. Could very well be an oversight or just product limitation; not necessarily that entire lines of products were optimized for the ASR test procedure... Or is there some telltales of intent in the design?
That aside, I think that this revelation could be a shock for many, who believed that the current set of measurements basically demonstrated that they would work equally well in all cases, or even better than, class AB or other more expensive amps... (YMMV, interpretation, etc.) Turns out this may not be the case... Kind of a big deal, here's an example; I mean, I'm not blaming anyone, as given the industry going with measurements and somewhat dismissing subjective reports or opinions in favor of objective data is understandable... But at minimum, a lot of assertions, conclusions, etc., should be re-examined given this new data.
