Replace OP amps. Completely pointless, or not?
Tangband
Sweden
Tangbands graphs show a low level power frequency spike, this comes down likely to poor implementation, though a better amp may alleviate. Then there is what looks like a power supply spike. Looks like the unit was powered by 60hz bench supply but used in a 50hz environment. Who knows what ground loops are there.
Its PMA:s measurements on the Aiyima a07 with ne5532 and lm4562. Its the same power supply used.
audio2design
Unless you have very sophisticated equipment simple measurement don't detect op amp clones.
audio2design
Here are some measurements. EG up to 20dB difference in SINAD:
Closer to 12db the other was the AP loopback. Constant across signal level suggesting purely noise or poorer PSRR. There is no decoupling between the caps and external supply so quite possible. It's a poor implementation and not representative of what may happen in a proper circuit.
antcollinet
UK/Cheshire
well spotted. I missed that one was loopback
DanielT
DanielT
Sweden - Слава Україні
Tangbands graphs show a low level power frequency spike, this comes down likely to poor implementation, though a better amp may alleviate. Then there is what looks like a power supply spike 3x50. Looks like the unit was powered by 50hz bench supply but used in a 50hz environment. Who knows what ground loops are there.
Well now the Aiyima A07 is not an expensive amplifier but poor implementation, not so good amp ... do you think so?
Tangband
Sweden
My counter-question. If so, why do not Aiyima themselves put in lm4562 from the beginning?
Because of cost . The ne5532 is almost for free. They are offering LM4562 for an additional cost .
a07 is a very cheap amplifier.
DanielT
DanielT
Well, hm ..Do you think that buying X number of LM4562 for Aiyima would mean such a big extra cost for them? Note I mean that: Why does Aiyima not design its amplifier with just LM4562 if they now think it is better?
levimax
San Diego
Cost difference is pennies... both are dirt cheap and preform well. Put me down as a skeptic... a few dB difference in SINAD at low frequency but still more than -100 dB down is not audible.
audio2design
I was speaking to the implementation of the op-amp in the circuit and why the two were different at 50hz and 150hz (if not measurement error).
Tangband
Sweden
counterquestion: Why do expensive amplifiers sometimes use TL 072 Op:s ?
In Aiyimas case: Probably it would have done the amplifier more expensive. After all, - lm4562 is 20 times more expensive. :)Thats the way all companies works- cut the costs where you can.
And maybe 90% of the buyers dont care much about soundquality also….. not for 70 dollars for a whole amplifier.
As I said earlier - Aiyima themselves recommends lm4562 as an upgrade and you can buy the amplifier from them with lm4562 , for an additional cost.
Tangband
Sweden
I just want to say that my Aiyima a04 with a meanwell 30 v 6 A power supply outperforms every class A/B amplifier up to about 500 dollars we have found (tested 5 amplifiers ) and done comparisons with, listening to music. Thats an achivement , and Amirms up-writing of the bigger brother a07 is entirely true.
Those amplifiers and the topping d10s are incredibly bargains, and a perfect beginning for audiophile students and such.:).
I also think that op-amp rolling is rather fun, even if the only op I found to be sounding clearly better than ne5532, was the lm4562 ( the others I tried: opa1642 opa2134 and opa1612 )
Tangband
Sweden
Okay, I'm quitting the speculation about why Aiyima chooses OP amp X. It can be due to a lot of different technical and or business decisions.:)
Yes, the thing that they have the option to swap the OP:s they have incommon with many other chinese amplifier or dac-makers like topping. Maybe the cause is to start an interest in modifying and starting a cult like a07 or d10s ?;)
Reactions: JRS
DanielT
DanielT
Very affordable. :DThe question is in any case at the price Aiyima is sold for if it is possible to find someone with better performance? . In the case of a two-channel amplifier (apart from the missing remote and only one input).
When it comes to comparing sounds. Tangband, well. I guess in my case I will not hear any differences, if I were to roll, switch up amps.
Went completely to he...l (or it went well as it went, as you might expect) when I was going to detect differences here:
oldsysop
:rolleyes:
