Bob from Florida
- Joined
- Aug 20, 2020
- Messages
- 1,313
- Likes
- 1,212
Why do so many OPs change amps in, for example, the amplifier AIYIMA A07 TPA3255?
What's the point of that? Does not modern OPs amps amplify the signal completely linear straight(if the construction they sit in is well constructed,
and made to fit OP amp X)? Do not modern OP amps have a distortion level far, I mean really FAR below the audible? What the hell is the difference in sound that those who change claim to hear? Is it just imagination or have I missed something now?
Tips for those who have a friend who can help. Just to test. OP amps are not expensive. Ask your friend to change them in, for example, your Aiyima BUT you will not find out when and if he has done so. It is entirely up to your friend to do, or not to do. Then in time, your friend will ask you if you heard, noticed any difference in the sound.
Variant two. Ask your friend to paste small notes on a number of OP amps. You do not know which OP amp is which. Then switch and listen. Also ask your friend to number differently even though some are the same OP amp.
I say good luck hearing any difference. I think those who test the above will not hear any difference. Personally, I had bought something other than the few money op amps cost. Pizza for example. Put on the bandage and ask your friend to buy some different pizza varieties and blind test. In any case, it's yummy ... You would get something positive from such a test.
Attached files, data from Texas instruments and Wikipedia regarding distortion levels regarding OP amp NE5532 and LM4562.Change from NE5532 to LM4562 there those who did just that. Why?
NE5532 - Wikipedia
en.wikipedia.org
View attachment 156675View attachment 156676
Change op amps if there is something audible being introduced by the op amp. Prime example is "hiss" caused by the op amp. You may be able to find a "drop in" replacement without any circuit changes that won't "hiss". Obviously measurable if you can hear the "hiss". Just one example of a valid reason to "upgrade" the op amp. If you are shopping specifications and the difference between op amp A and B is below hearing thresholds - why bother? Battery powered devices would benefit from a lower power consumption op amp all other parameters being equal. Or maybe you are just "itching" to change something. Changing Op amps is the solid state version of "tube rolling" come to think of it.
As a manufacturer the way to discourage op amp rolling is to solder them to the board. That will separate the "men from the boys" especially with surface mount op amps.
