- Thread Starter
- #61
Thanks That alcove does look like hard work to treat.
I agree with @maverickronin - try to do what you can to put as much absorption in it as possible.
I am not sure how much that will help with lower frequencies. I feel the alcove getting pressurized by the subwoofer and when I move myself to the edge of the seat, its almost as if the sub was turned off. As @mitchco pointed out earlier with amroc tool, this area has a severe room mode.
I've been trying to get some measurements using REW (it was easy for my living room. In the basement, my first round of measurements was inconsistent with another one so I started from scratch) but I am struggling with it in the basement to set the target level (the frequency response curve is literally off the chart and I didn't get any clipping warning during the measurement or in the "Check level" tool). I'll have to take measurements in the living room again to make sure I am doing things right and go back to the basement.
