Revel M105 Bookshelf Speaker Review
Do any of the measurements give an indication of how they sound at low levels? A few press reviewers comment on this, but it is rare, and here the talk is about how loud they can get--something I don't care that much about.
They work the same as far as the speaker goes. Here is the comparison of 86 vs 96 dB SPL (in room):
There is no difference other than noise intruding when the output of the speaker gets too low in bass.
daftcombo
How come you don't have room modes under 100 Hz on this graph?
hardisj
Reviewer
North Alabama
This is great. Is it possible to run it with a simulated 80hz high pass, e.g. a default sub crossover, I'm interested in how the midrange changes when no longer asked to do as much low down. I'm hoping it cleans up a lot, it's my impression from trying such things.
You might be interested in this 'study' I did. I tested a speaker with a 20-20kHz stimulus. Then tested it again with an 80-20kHz stimulus.
https://www.audiosciencereview.com/forum/index.php?threads/erinsaudiocorner.11219/post-458455
I mentioned in one of the more recent posts that Klippel recently updated the build version and with that came the new versions of their ISC & MTON modules. You can read more about what these are above or watch the video. The net effect, however, is thanks to these two modules I am now able to gather accurate distortion data in the farfield as an anechoic measurement. :D
There are numerous templates available in the MTON module (you can read about them if you have access to the IEC standard referenced on their product page; I do not have this nor the $350 to buy it :rolleyes:). I played with each yesterday (at least, the ones that made sense for a passive loudspeaker) and prefer the "Long Term max SPL" test. This was the one shown in the above video. I haven't decided *for sure* that this is how the tests will all be conducted going forward but, for now, I am going to share the results of the testing because it truly is next level analysis.
The DUT is the Neumi BS5. Here's the link to the review:
https://www.audiosciencereview.com/forum/index.php?threads/neumi-bs5-bookshelf-speaker-review.14404/
I ran this test twice:
First from 20Hz to 20kHz.
Second from 80Hz to 20kHz.
Voltage stepped in 1V increments set up from 1V to 30V.
In this "long term spl max" testing the compression limit was set to 3dB and the maximum distortion level was set to -20dB (relative to the fundamental), equaling about 10% distortion.
First Test: Stimulus from 20Hz to 20kHz.
I'll provide the graphics with a short explanation of what each means.
This table shows the max distortion test results. The top line tells me that the DUT hit max SPL due to hitting maximum compression.
The second block tells me what the maximum SPL value is (relative to 1 meter). In this case, the max SPL ~ 82dB.
This block also tells you the compression at this SPL (4.68dB) and the max multitone distortion (-29.62dB; ~3%).
Knowing there are two limits set for Multitone distortion failure (compression and/or distortion, mentioned above), let's break the results down in to those sections.
1) First, compression-oriented results:
The below graphic shows the stepped voltages. The 1V line (solid blue) is the reference to which all other measurements are compared. The dashed blue line is the compression limit relative to the 1V output; which is -3dB from the reference. The red line is the case that exceeded whatever threshold (compression and/or distortion as described above). This will always be the case. Red will always be the final measurement. As you will see below, if multiple voltages had passed there would be additional lines besides the reference (solid blue) and the failed (red). In this case you can see the measurement exceeded the -3dB compression limit at approximately 20Hz (noted in orange below).
Now, this is the same thing as above, but simply "normalized" to the 1V reference measurement. I prefer this version as it's easier to identify the failure modes more quickly.
And, finally, this graphic just gives you the voltage vs compression. I don't find it particularly useful. Single points of data tell me nothing I want to know. So don't be surprised if you never see this from me again:
2) Now let's look at the distortion-based results of this multitone testing...
Below are the results of the various voltages' distortion, relative to the fundamental. There will be n-1 gray lines (where n=# of voltages ran in the test; in this case, 2-1 = 1). The green will always be the last measurement. The dashed blue line at -20dB represents the multitone distortion threshold. This is set up in the template so apparently is the IEC standard. I can change it if I want to. Not sure I will. TBD.
As you can see, none of the voltages increased above the -20dB MTON threshold. Which we expected, as the table I provided first told you that compression as the cause for max SPL being reached. Noteworthy here is the 1V measurement shows a higher distortion value below about 100Hz. This is likely an effect of noise floor. I imagine most every case I run will have a similar result with very low voltage (where the signal isn't strong enough to drown out any external noise because testing is done in my garage), however, the noise will almost always be below the -20dB threshold and increasing the voltage lowers the noise floor. But I need to check with the folks at Klippel to see if that logic flows. Anyway...
This graphic provides voltage vs relative distortion. I'll probably never post this again; single points of data are useless to me.
Alright. Those are the two components for determining max SPL. Again, you can see that the -3dB set for compression threshold failure is exceeded at 20Hz and therefore the (at least in this case) cause for SPL maximum of 81.93dB.
But, given that I think it's hardly fair to expect a small bookshelf like this Neumi BS5 to realistically play down to 20Hz, I ran a separate test with the stimulus spectrum set only from 80Hz to 20kHz to see what the maximum SPL might be closer to in a real-world situation. Note: as of this moment, I do not know a way to apply a shaped stimulus to emulate a nth-order filter. So for now, this "brickwall" of 80Hz will have to suffice.
-------------- (break) --------------------
Second Test: Stimulus from 80Hz to 20kHz.
Now, let's see what the results look like using a limited, more realistic for a bookshelf speaker, stimulus of 80Hz to 20kHz.
So, that's it. This test method isn't cemented just yet. I'm going to explore the other modules and shaping stimulus when I have time. But, it gives you an idea of where I am going. Overall, I think this is fantastic news as it gives me a repeatable, highly accurate way to determine the actual maximum SPL based on a set of conditions that make sense for the average user.
With this limited stimulus the result of max SPL testing is:
Whoa! Now we have a maximum SPL of 95.65dB with compression at 3.37dB. The Multitone distortion at this output level is -40.13dB (1%).
That's a big, big difference from the 20-20kHz test results.
What are the corresponding results?...
Well, the -3dB compression limit was reached at about 1.37kHz. But barely.
How barely? By about 0.37dB.
And here is the graphic I said I wouldn't show again. Maybe I'm softening. At any rate, this one shows the max compression value relative to voltage input. Note how the curve is not linear (isn't that an oxymoron?... meh, you know what I mean).
So, how does the distortion look, then? Well, the -20dB limit is never reached. But, if I were to change this -20dB (10%) to 3% (-30dB) it still wouldn't have been exceeded with this limited stimulus at the compression limit voltage of 9V.
There you have it. Using a limited stimulus allows a higher SPL. Makes sense. But, most importantly, we have a repeatable, accurate method for determining maximum SPL with the underlying factors for why the SPL is limited to x dB. Pretty awesome. ;)
Additional stuff:
To me, it's interesting to compare the overlapping voltages' distortion and compression profiles. So, let's do that. Remember, with the full 20-20k spectrum I was only able to provide a 2V input before reaching the max SPL. That's where Test 1 and Test 2 will overlap, then. So, let's directly compare what the MTON distortion and compression curves look like using 2V (I could have used 1V as well but I'm trying to save some time here):
First, this assumes 1V (reference) measurement is the same, so let's look at that by way of looking at the two compression limits (blue for the 20-20k and green for the 80-20k):
Hey, they are almost identical. Good enough for me to continue on...
Now, let's keep these compression limits but also add the 2V comparison between the full stimulus (red) vs the limited stimulus (gray). Remember, the former failed at 2V due to exceeding the threshold at 20Hz while the latter failed at ~1.37kHz. Still, how much does the limiting of excursion on the 5-inch woofer drive a change in the compression profile?...
Not a lot of difference here. A couple dB here and there. But not much; and they both only seem to deviate where the 1V (reference) for each respective measurement lies. Okay.
Moving on, let's compare the MTON distortion profiles using the same voltages. Green = Full spectrum (20-20kHz) and gray = 80-20kHz).
Interesting. The limited signal result is between 5-10dB lower in distortion until you get to about 2kHz. This shows that the woofer playing low is causing additional distortion throughout the mid/woofer's passband.
But, even beyond that, above 5kHz there is a pretty drastic difference as well with some portions reaching 10dB more distortion :
So, what can we learn here? Well, things we either already knew or would have logically assumed: a multitone signal is more dense and therefore more stressing than a single tone stimulus like a harmonic distortion or even a two-tone stimulus like an IMD test. This is a good way to resolve complex distortion drivers that wouldn't otherwise be shown. Notably at points far away from the loudspeaker's drive unit's individual Fs (where, typically, suspension related distortion is prominent). However, I didn't expect the difference in distortion to be so significant as high in frequency (even out to 20kHz) by simply limiting the stimulus above 80Hz. That was really eye-opening.
...... aaaaaaaaaaand... done.
Once I settle in on a test method I'll figure out if I want to use Klippel's default window for providing results or write my own script. In this case, though, I think I like theirs just fine. In other cases it made more sense to write my own. That was a topic of conversation in our hour-long skype session a couple weeks ago. They asked for feedback on their graphics (they noticed I was using the data but writing my own scripts for plotting). It looks like some of my suggestions may have already been incorporated. I'll be beta testing their next major release for next year and I'm excited to see what they have changed with their GUI.
That is usually done with one tone. You could write a program to exclude the 32 tones and compute the RMS value. It is just not included in AP software.
I do. That is what the variations in bass are (compare it to spinorama curve). However, they are minimized because the microphone is only 13 inches/0.3 meter from the speaker. So direct sound dominates. This is also a very large space so that helps too.
Robbo99999
Good review, I enjoyed that one! The speaker does actually look gorgeous on an aesthetic level too...looks almost edible...in Milkybar style (not that I like Milkybars but it looks tasty!).
@amirm , for your High Pass Filter at 30Hz, do you ever find it helps to use similar High Pass Filters but at lower frequencies for the larger more capable speakers or do you start to lose some bass character if doing that on more capable speakers? I tried a High Pass Filter on my JBL 308's and I found it took out too much rumble, I do use one on my headphone EQ's though, I do 12Hz High Pass at 0.75Q and that basically starts removing bass from 20Hz and below....I noticed it improved clarity on my NAD HP50's that are capable of playing very low bass flat to 10Hz....and I think I noticed improvements on my AKG K702 too....albeit both headphones have approx 5dB Low Shelf Boosts, so I think the High Pass Filter removes that excess bass where it's not audible.
Dj7675
Thanks for posting the link. It was interesting (and some beyond what I current know) I own the M106 for mains in 2 rooms and m16 as surrounds.
It seems as though this important because often times, that is how bookshelves are used.. with crossover around 80. The main point being when used with subs and crossed over at a reasonable point, the low end distortion is improved (expected) as well as higher frequencies (not expected by me at least). Thanks again for linking.
dc655321
AFAIK, a single tone is not a requirement for this metric - it would require the multi-tones to have the same amplitude though.
Do you publish that data somewhere so others can scrutinize (i.e. as with the NFS data)?
Sancus
Not to be challenging but I just read from the FR curve Of both, seems the revel reach the -5db Mark of Bass roll off around 70hz and the KH80 at 60 hz? Just by that it seems the Neumann can dive lower in bass, but of coz not in a big room which is where flood standers should go no?
Sure but extension has absolutely nothing to do with output capability. Most active speakers use EQ to boost their output in the lows but this isn't sustainable at high SPLs which you can see in the graphs I posted, the 5" KH120 gets nearly 10dB louder at 100hz before hitting 3% distortion.
Rick Sykora
Stow, Ohio USA
@Amir thanks for the ongoing efforts! May I request that you post the speaker dimensions? The pics are great, but want to know how much speaker am getting for the money!
daftcombo
Is your high pass filter minimum phase or linear phase?
On Behringer B2030P, it did take away some bass so I did not use it on that. So yes, it is not a universal solution for anything that produces good bass. Then again, I am quickly dialing in these filters based on intuition (!). One can optimize them more based on measurements and more time spent listening.
@Amir thanks for the ongoing effort! May I request that you post the speaker dimensions? The pics are great, but want to know how much speaker am getting for the money!
They should be in the company specs, no?
daftcombo
I don't remember if i tried it with these speakers or another one I tested recently. At higher frequencies it will take out some of the bass. Using the one I have here, there is no bass impact and just improvement in distortion.
As for slope, 36 dB is the highest available in Roon and that is what I used.
RePhase allows any slope, including a brickwall :
linear phrase or minimal phase.
In red: Linkwitz-Riley 36dB/oct at 30Hz.
In blue: brickwall at 30 Hz.
I'm not sure if too steep a slope, even linear phase, wouldn't sound weird if the cut frequency is above 20 Hz.
You are trying to create more work for me???? :)
The data file is quite large as it is every pixel on the graph. I just exported it. Here it is:
So not sure how useful it is.
  • Multitone.zip
AP has built-in sharp filters so if that is what people want, that is easy to test.
Jimbob54
Alas, not cat proof so yet another fantasy purchase that shall remain just that.
Rick Sykora
Stow, Ohio USA
Robbo99999
Hmm, I don't know, it's just the High Pass Filter in PEACE - an extension of Equaliser APO. You can set the Q value to whatever you want, I use 0.75Q.
Which one would it be, minimum or linear & would it matter?
