- Joined
- Jun 5, 2020
- Messages
- 4,815
- Likes
- 3,752
Can you name them? I'm sure others will be curious.Yeah you are right. I prefer the M16's to some 3-4.5 k speakers I have and its not close.
Tekton is one .Can you name them? I'm sure others will be curious.
Revel are getting harder to get hold of in the UK. Only Superfi out of the national chains seem to stock them (30% off the M16’s at the moment). I bought a pair of ex-display M16‘s from Richer Sounds for £380 ($525) last week. I wasn’t planning to ‘up grade’, but it was way too good a deal to pass up. I was curious to see how they would compare to my PMC Twenty5 21’s (RRP £2000 when they were the current model).
Subjective impressions are as good as I’d hoped. The PMC’s are going!
not sure but i prefer the Revel's over the R3'sdo everyone think there is a new version coming out soon if they are selling it out?
i'm starting to consider these over Kef R3s...
I'm trying to read the vertical dispersion results to understand how far ABOVE the tweeter axis one can listen without problems. (I use three of these along my front sound stage and since my display is at ear level, the center speaker sits lower than the left and right.)
I think my 20 degree angle is just on the borderline of introducing issues based on what I hear. But this graph would be definitive.....if I could figure out which gray line is which gray line....
This graph appears to confirm that things get a little wonky between 2000 and 3000 (??) hz if one is sitting very far off the vertical axis?
I will be adding tilt to the speaker stand, which will put my ears closer to being on axis vertically.
Agree you spot on and better tilt them if not within +/-10º verticals ..Thanks. Looks like 10% is the sweet spot (pun intended) and that between 10 and 20% off vertical axis things get impacted quite significantly.
I'm not sure, it seems like the response is already 2-3dB down at +/- 10 degrees. would not recommend sitting off vertical axis at all.
And for anyone needing some quick maths:
tan(10°)•distance=height
So 10ft away would put it at ~21” above tweeter.
The unit reviewed is his own (he states so in the review). He uses it from time to time for comparison with other speakers.I suspect he sent this back to the owner a long time ago.....
