Haint
- Joined
- Jan 26, 2020
- Messages
- 347
- Likes
- 454
Have you measured your F35's in room? My F36 are crazy flat out to 20 KHz. From my understanding, if a speaker is flat to 20 KHz it will have a gentle downward slope out to 20K in room. Mine have no roll off at all....almost makes it seem like room correction is forcing them flat but I'm only eq'ing below 500 Hz. Don't judge too harshly below 300 Hz. This was a quick and dirty setup with subs too low in level and not dialed in yet. Also some furniture blocking the woofers that I need to change.View attachment 53532
If you set Audyssey to Flat I believe it ignores your cut off point preference and corrects the full range, you have to use Reference to successfully limit it. Turning on Dynamic EQ will also start applying a treble boost from ~7kHz to 20k regardless of your cut off point. This is what I see on F35's, Center MLP at around 9' distance.
1/6th Smoothing | Green: Audyssey Off | Red: XT32 Reference, Limited to ~500-600Hz, Dynamic EQ On (10dB Reference Offset).
