- Joined
- Jan 7, 2020
- Messages
- 948
- Likes
- 1,262
Im in, still use my original E1DA.
2.5mm
2.5mm
Search for "2.5mm 2pin cable" on places like Amazon, AliExpress, eBay. There are hundreds of cables to choose fromI would like to try them with my 9038SG3. I anyone aware of a cable for that?
The Tripowin zonie (different plugs available) is pretty decent. Around £15 from amazon.On a different note, I am just now listening to 7Hz Salnotes Crinacle Zero:2, my first "cabled" in-ears apart from those that cheapo things that come with phones.
They came with a cable that is 3.5 mm TRS to those 2-pole fork-like things that plug directly into the earpieces. I have no idea what they are called. So I am listening with 9038D, and the combination is pure bliss. I would like to try them with my 9038SG3. I anyone aware of a cable for that? If not, I will have to order cheap headphones and sacrifice the cable to solder my own 2.5 TRRS in place of the 3.5 mm TRS.
I have read about these “out of phase” issues with the CS43131/CS43198. I think Wolf measured a Zishan device showing that very issue. I have also read that the fix is fairly simple (some registers?)."dual cs43131" and dual outputs, balanced and unbalanced. They used the second cs43131 in fact as an inverter to get a balanced output + a noticeable phase difference ))
I hope these kind of lame excuses are a thing of the past now , jump to it Amirm, our friend Bill has already saved the world 3 times in the time you took to chose your underpants this morning ..My 33 ohm load is unbalanced. Don't have time to build a balanced version right now given my workload.
Well, I've seen a screenshot of the delivery note from Aliexpress (from 2020) and it clearly says Susumu 3000 3000 µF. Apparently, the original Susumu edition was a 3000, and did not have those markings. I ordered my Susumu 2000 nearly a year later.it is not S3000, indeed.
all details you can find on the previous pageDid the 9038S not employ a composite op amp? Can you say what types of opamp you were / are using now?
