Review and Measurements of Grace Design Balanced DAC
Interesting. Does the shield of the balanced cable have to be lifted to isolate ground loops?
No because it doesn't play a role in signal delivery.
Reactions: PSO
Labjr
I run the mixing board for a local rock and roll band. I frequently have ground loop hum in different night clubs. It usually goes away by unplugging the cable to one of the stage monitors or some other piece of equipment and they all use balanced XLR cables?
There is a limit to common mode rejection in equipment. If you exceed that, or equipment is not designed well, you still get hum.
PuX
it's on sale again.
what kind of XLR cables are 'good enough'? I remember amirm once said RCA for Amazon basics are good, what about XLR? they do have an XLR cable, but it's 6 feet (longer than needed in most cases) and sold as a single cable, not a pair. any other options? does it matter if it says 'microphone cable'?
AresHarvest
it's on sale again.
Doesn't matter if it says microphone cable, that's just one application.
As for which are good, they're mostly equal in that regard but non-name-brand connectors can vary in quality (snugness, strain relief, housing finish). I prefer making mine with Canare cable and Neutrik or Amphenol connectors.
Here's a pair of 2-foot pre-made cables that use those parts https://www.amazon.com/dp/B07MSP6X5T/
Labjr
it's on sale again.
Mogami W2549 is popular bulk cable. Supposed to be neutral sounding. With some basic soldering skills, it's pretty easy to make your own cables.
waltzingbear
Portland, Oregon
Mogami, Canare, and Gotham are all good (to excellent) cables to use. My favorite xlr is Neutrix, come in gold, silver or nickle contacts. You can order custom made cables from Redco.com with whatever cable (that they carry), length and connector. Just choose the custom cable tab. They genrally supply the pro audio world.
as an aside, you do not need to have two chips to do balanced, one reason is that there are a number of fine chips that do the deed in one chip. DRV134 from TI and THAT126x are two options that go from unbalanced to balanced that will drive just about anything and have excellent specs.
Cheers
Alan
Reactions: PSO
PuX
nice, Redco.com prices seem reasonable. although lots of choice can be overwhelming.
waltzingbear
Portland, Oregon
star quad had higher noise rejection and higher capacitance per ft for signal. Depending on equipment used it may cause a difference.
Will Markertek make custom cables, news to me. Good if they have what you want.
KimbaWLion
I use Cardas Hexlink Gold. While not considered their best cable any more I like how my XLR connector cables look work so no complaints from me...
Julf
Amsterdam, The Netherlands
Pretty much any XLR cable is good enough. The main cost is the connectors.
Rem
Would introducing a random wall wart be bad for measurements? I have a random USB phone charger wall wart that fits the spec for it but... hmm.
Zerviscos
Inside a space whale
Hmm. Buying the SDAC-Balanced for the unbalanced output temporarily...for probably 1~2 years or longer before i probably decide to get a balanced amp. Do you think it's worth the investment over the modi 3? Tbh, I don't even know if I might buy a balanced amp anytime soon, but seeing as there's a buncha used good balanced amp that retail for around $150 to $200 like the H10 Gustard, I was thinking maybe the flexibility is worth it.
Veri
Well if you want a balanced DAC for future proofing then yeah it's perfect, cheap.
RickSanchez
Cartographer
Austin, TX
If you don't absolutely need a DAC right now then it makes sense to wait. Get what you need when you need it; there will be great (high quality, good measurement, inexpensive) balanced DACs in 1-2 years .... probably more than we have now.
If you need a DAC then personally I'd go for the Grace balanced SDAC. As Veri mentions it's worth it for future proofing. In addition to that I took a look at Amir's review of the Modi 3 and I was concerned about the issues he encountered with the USB input.
