Review and Measurements of Hypex NC400 DIY Amp
Julf
Amsterdam, The Netherlands
All good here? Bought this used and I don't really know what I'm looking at
The speaker output leads are pretty bad, forming an enormous loop antenna.
Julf
Looks like an nc400 old module(red caps) with a smps 600 power module. Only one nc400 module, I think you get a mono amp
Yes, definitely mono(block).
HeavyMantra
Can you simplify this for me
How big of an issue is it?
And yes, I bought a pair of course
The cables are Bertram proxima 2 silver if that matters
Julf
I can try. Bruno (the designer) has been pretty clear about how the output wires should be twisted together (just like the mains power wires in your amp) pretty tightly (even to the degree that they should not exit the output connectors in opposite directions) in order not to form an antenna that feeds into the feedback circuit.
Hard to say without measuring.
All that matters is sufficient cross section (and the twisting). Those cables don't look very thick - what is the point of a non-circular cross section?
HeavyMantra
Thanks, most of these terms are new to me. The first time looked inside an amp was yesterday! Do you mean that the flat, silver looking cables should be twisted together?
The issue would be some kind of hum or interference? Can it be fixed by twisting the cables?
Have gotten what seems to be a good deal for the pair (about 1000 euro) but since I'm not tech savvy I don't want to buy something home-built if it could have big issues
Eirikur
Looks like some sort of FM/VHF antenna wire is used towards the binding posts, pretty thin at that:
Also, seems the XLR connector is only half-connected (red) and possibly not even properly grounded (yellow).
Perhaps a more knowledgeable Hypexpert can comment on this.
This is the schematic approach for the DIY Hypex nCore NC400, notice the twisting as @Julf mentioned
Julf
Yes, except you would be better off with normal, round copper cables.
Noise or even high frequency oscillation (causing amp to run warm).
Yes.
You might be OK, but it is definitely against the recommendations of the designer.
HeavyMantra
Thanks a lot. I think I'll go ahead and seal the deal and fix this later
HeavyMantra
Thanks, is the XLR not being connected and grounded something that could be fixed easily?
Julf
HeavyMantra
I've asked the seller about these things, hopefully I will know more soon including what the silvery flat cable is. I hope to be able to go ahead with the deal and fix any issues.
Julf
Hopefully you don't get any flowery BS about how the silver cable is somehow better...
HeavyMantra
I probably will. I haven't read much about the cable conflict but I know it exists and that I won't prioritize really fancy cables even if it they were better
But you're saying it's worse than a copper one even?
Julf
The material is OK (but not better either), the shape and thickness/gauge are the issues (besides the twisting).
Julf
So good to know. Is it only the flat silver one that has this problem?
Yes, and even there the only problem (again apart from the twisting) is a slightly larger output impedance / lower damping factor, so nothing major.
HeavyMantra
Thanks for the help, I went ahead and bought them. The minimal design is worth some potential hassle
veeceem
I have the new NAD M22 Version 2. it's a custom NC400 board/layout made exclusively for NAD using NC500 output. It's an incredible amp.
Are the RCA/XLR connectors on this amp soldered directly into the PCB? It seems that way to me :/
Btw, it seems that the 2 smaller board are the amp modules? What about the bigger PCB which the connectors are soldered into?
6speed
Virginia, USA
@HeavyMantra I would want to get the AC cable away from the SMPS transformers and inductor, which is as simple as tying it down between the SMPS and NC400. Also get the speaker cable going to the black binding post away from the output inductor, which is as simple as turning it to exit the screw-down connector the same direction as the other speaker cable.
