Review and Measurements of IOM NCore Pro PWR Amp
cinstance
I just build one of this for about $400 total.
I bought the case and all cables and connectors needed from ghentaudio for $130:
https://www.ghentaudio.com/kit/2180a-2.html
and bought the 252MP from Ebay for about $250.
Everything were put together in less than one hour and it works great. It has very smooth and sweet sound for the tweeters, but not so great for mid and bass drivers. So I am using it for the tweeters in a bi-amping set up.
Matias
São Paulo, Brazil
Class D sweet on highs and not good enough on mids and bass... This just shows how much the world is changing. :)
VintageFlanker
Paris
@Audiophonics just listed another release.
After, their amps based on NC122MP, NC250MP, NC500MP, and more recently, NC400. Now, they just released a NC252MP based one! Only XLR inputs this time.
Most impressive thing here is the price: 439€ VAT inc. Pair this with a SMSL M500 and you get a endgame set up for most usages for only 838€.
https://www.audiophonics.fr/en/powe...reo-amplifier-ncore-2x150w-8-ohm-p-14185.html
1573040817415_audiophonics-mpa-s252nc-xlr-amplificateur-stereo-class-d-ncore-2x150w-8-...~2.jpg
1573040816163_audiophonics-mpa-s252nc-xlr-amplificateur-stereo-class-d-ncore-2x150w-8-...~2.jpg
1573040819185_audiophonics-mpa-s252nc-xlr-amplificateur-stereo-class-d-ncore-2x150w-8-...~2.jpg
daftcombo
Thanks!
Seems like this is what I need for my newcomers Focal Aria 906!
RichB
Massachusetts
The price is right but these are not inspiring specifications:
Max. power (@ 1kHz, THD=1%)
2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
The power versus distortion charts are illegible.
- Rich
VintageFlanker
Paris
2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
- Rich
What @daftcombo said. Check the specs from the datasheet. All will match since this is nothing but a NC252MP module in a box.
In the same order of idea: @amirm measurements for the ION are applicable to the Audiophonics one. (Just much better looking to me and 200€ cheaper!).
dkinric
Virginia, USA
Wow, great distortion and power #s for only about $400 USD. Case looks nice. This could be "the one" (for me, at least).
Edit: $544 after taxes and shipping to USA
rodtor
Toronto
Hopefully this is the case. But we can never be sure whether an implementation meets Hypex specs until it is tested. The IOM, based on the 252MP, came very close. However, the Nord implementation of the Hypex 500 fell noticeably short of the specs for that module. The Audiophonics units look great to my admittedly untrained eyes. But it would be nice to see independent test results for a couple of their units, as well as others from Apollon, Nord and March. With that proviso, I do share your enthusiasm for units based on these modules.
VintageFlanker
Paris
Unfortunately not comparable. There is no "implementation" for the NC252MP. This is a all in one module. It is the only component needed to build an amp.
NC500 needs (custom?) buffers/opamps and a SMPS to operate. That explains some little performance variations.
rodtor
Toronto
That particular Nord used an opamp from Hypex. And what would Hypex's specs be based on. We don't know what custom opamp will do to performance because they, too, have not been tested. A number of contributors to various ASR threads have pointed out that implementation is always key, even for Hypex modules. It is not just a matter of sticking a couple of components in a box.
dwalme
With the NC252MP it is exactly a matter of sticking a module in a box and you are done.
The Nord NC500 based amplifiers are not like the amplifiers built with NC252MP. No alternative power supply, no custom input buffer, etc. You literally bolt the module into a case and connect your power wires and audio input/output wires. Done.
rodtor
Toronto
OK, thanks for claritying that for me.
headshake
Hmmm.,, made me look. There is a US based seller that has the 252mp for $289 shipped.
That's damn tempting. I thought the plate amps were a deal... this might top it.
Just need a few connectors and a case (if i skip ghent).
Why? More watts?
boXem
Europe
These modules are not supposed to be sold to individuals. This means this guy got something he was not supposed to get, or lied at some point. Not somebody I would trust by default.
cinstance
Why? More watts?
Yeah, probably. My speakers are very power hungry. With the 252MP, the base does not have the same depth and impact as with the QSC PLX3002 which I am now using for the mid and base drivers.
BaaM
I've just bought the AUDIOPHONICS MPA-S252NC XLR.
Will share my subjective opinion here and compare it to my FX Audio D802C as soon as I find out a good DAC (within ~two weeks)
