Review and Measurements of Okto DAC8 8Ch DAC & Amp
waynel
Nope can't see appeal or reason for 8 channel dac, what what said earlier up with minidsp I'd never do
This is not the DAC you are looking for.
kevinh
Oh sorry did not know you are talking about digital only. I think digital only should have the same performance as PC because it is just calculating maths in the chips. The adc and dac in minidsp are not very good measuring.
Well IF I was talking about a analog output from Minidsp products there would be no need for the Octo.
The SHD that Amir reviewed had IIRC pretty good specs.
Veri
And, let me remind all of you again just for sure;
DAC8PRO's high quality Headphone OUT is another line-level analog out of CH-1+CH-2 "under the control" of gain and master volume. If you like, you may use it as RCA unbalance OUT of CH-1+CH-2 with gain and volume applied.
https://www.audiosciencereview.com/...ssover-and-multichannel-dac.12489/post-420921
Hmm isn't this kind of thing prone to (grounding) noise? Not to mention how erm, elegant it looks :D
John1959
Netherlands
Anyone heard any more news about firmware updates? It's been a while...
Nothing heard from Okto recently. I have FW version 1.34 in my DAC8 PRO, shipped end of June 2020 and don't know about more recent ones. I have no problems with this version or with the DAC in general so I am not keen to replace it unless some marvelous new features come with it (which I don't expect, it's just a DAC anyway :)).
John
Vincentponcet
John
I'm curious to know the FW release notes.
I have FW version 1.0
John1959
Netherlands
1.0? I can understand you are curious about the changes. I don't know if there are FW Release notes but if I remembered well Pavel from Okto Research has posted a little info about some features and bug fixes in FW upgrades. I can't find exactly where, possible not this forum, but if I find it I will post links. Best of all is an answer of Pavel himself of course.
Neddy
Wisconsin
https://www.audiosciencereview.com/...kto-dac8-8ch-dac-amp.7064/page-78#post-408327
https://www.audiosciencereview.com/...kto-dac8-8ch-dac-amp.7064/page-82#post-450024
Verausci
In all FW versions, the menu settings are only stored when a soft power off is performed (no matter if using knob or remote) in order to save flash memory write cycles. The settings from the last session are lost if power cord is pulled, so this behavior is normal.
Is this still a thing? This is really concerning for me, as I always turn the power off at the wall when I go to bed or won't be using devices for some time.
What is the default configuration? How much messing around will I need to do to restore a 5.1 config? I can live with changing the volume back every time I power it up!
dualazmak
dualazmak
At least with my DAC8PRO (firm 1.32) in my multichannel environments, the RCA unbalance headphone OUT signal (CH-1+CH2) is working perfectly with no (grounding) noise. The spec of the headphone OUT is as good as XLR balance out.
In DAC8PRO's Owners Manual, we can read;
Analog connectivity
Main outputs (back side)
8 x Neutrik gold-plated XLR connector
Output level: 4.1 V RMS differential full-scale
output impedance: 200 Ohms
Headphone output (front side)
6.3 mm (1/4”) TRS connector
Output level: 4.1 V RMS full-scale
120 mA linear output current
fixed to output channels 1 and 2
output impedance <100 mOhm
waynel
dualazmak
With my DAC8PRO (1.32), all of the relative gains and master volume are memorized/retained both by hard off (plug off) and soft off, and all the values at the time of hard off (plug off) and soft off are correctly reflected on next power-on, very nice!
TonioRoffo
So, all we need to make a kick-a** quality receiver, is hack a fairly recent one.
Find the I²S channels before dac/volume, convert them to AES/EBU, route to MiniDSP 88D, do bass management & Dirac there, output AES/EBU to the DAC8PRO, connect a bunch of ncore/eigentakt amps & nice speakers, profit.
Verausci
Great that's good to hear. Can anyone else confirm this is the case with theirs?
Neddy
Wisconsin
Yes. But I always do a soft power off before hard (which is rarely, since I use the Okto remote & 12v out to power up/down all the other gear!).
dualazmak
Yes, again! Just same as Neddy said, I always do a soft power-off followed by hard-off by a multiple power distributor supplying power to all of the gears in my audio system.
Neddy
Wisconsin
Yes, and is kind of neat controlling ~ a couple of kW of power with that tiny little remote!
:eek:
Verausci
Thanks for the responses on the power-off save uncertainty!
In all FW versions, the menu settings are only stored when a soft power-off is performed (no matter if using knob or remote) in order to save flash memory write cycles. The settings from the last session are lost if power cord is pulled, so this behavior is normal.
I initially interpreted stored as kept, which lead me to think the settings would be lost on a full power-off. Judging from the responses, I think what they were saying is that a soft power-off is used to save the current configuration to memory. Once saved, a full power-off can be performed without losing the current settings. If however a full power-off is performed with 'unsaved' changes, these changes will be lost.
Actually that leads me to a (hopefully) final question on this issue:
Once the settings are saved with a soft power-off, can multiple full power-offs be performed and the settings kept? Thanks.
