wineds
Can you also post aplay -L (note capital L) ?
[46144.518557] usb 1-1.3: New USB device found, idVendor=20b1, idProduct=2009, bcdDevice= 1.20
[46144.518564] usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[46144.518570] usb 1-1.3: Product: DAC8PRO
[46144.518575] usb 1-1.3: Manufacturer: OKTO RESEARCH
[46144.518579] usb 1-1.3: SerialNumber: 000060
[46144.616850] usb 1-1.3: 1:3 : unsupported format bits 0x100000000
[46144.673320] input: OKTO RESEARCH DAC8PRO as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.4/0003:20B1:2009.0002/input/input1
[46144.738037] hid-generic 0003:20B1:2009.0002: input,hidraw0: USB HID v1.10 Device [OKTO RESEARCH DAC8PRO] on usb-0000:01:00.0-1.3/input4
[46153.506647] usb 1-1.3: USB disconnect, device number 4
[46186.038794] usb 1-1.3: new high-speed USB device number 5 using xhci_hcd
[46186.169493] usb 1-1.3: New USB device found, idVendor=20b1, idProduct=2009, bcdDevice= 1.20
[46186.169500] usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[46186.169505] usb 1-1.3: Product: DAC8PRO
[46186.169511] usb 1-1.3: Manufacturer: OKTO RESEARCH
[46186.169516] usb 1-1.3: SerialNumber: 000060
[46186.284972] usb 1-1.3: 1:3 : unsupported format bits 0x100000000
[46186.341272] input: OKTO RESEARCH DAC8PRO as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.4/0003:20B1:2009.0003/input/input2
[46186.408956] hid-generic 0003:20B1:2009.0003: input,hidraw0: USB HID v1.10 Device [OKTO RESEARCH DAC8PRO] on usb-0000:01:00.0-1.3/input4
[48182.283416] usb 1-1.3: 1:1: usb_set_interface failed (-110)
[48182.959167] usb 1-1.3: 1:1: usb_set_interface failed (-71)
noted, srry about thatCan you also post aplay -L (note capital L) ?
volumio@volumio:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dmix:CARD=ALSA,DEV=2
bcm2835 ALSA, bcm2835 IEC958/HDMI1
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=2
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=2
default:CARD=Headphones
bcm2835 Headphones, bcm2835 Headphones
sysdefault:CARD=Headphones
dmix:CARD=Headphones,DEV=0
dsnoop:CARD=Headphones,DEV=0
hw:CARD=Headphones,DEV=0
plughw:CARD=Headphones,DEV=0
default:CARD=DAC8PRO
DAC8PRO, USB Audio
sysdefault:CARD=DAC8PRO
DAC8PRO, USB Audio
front:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
Front speakers
surround21:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
4.0 Surround output to Front and Rear speakers
surround41:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
dsnoop:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
hw:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
plughw:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
ok so can you select this in Volumio ? :
volumio@volumio:~$ aplay -v Gottschalk.wav -D surround71:DAC8PRO,0
Playing WAVE 'Gottschalk.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
aplay: set_params:1297: Unable to install hw params:
ACCESS: RW_INTERLEAVED
FORMAT: S16_LE
SUBFORMAT: STD
SAMPLE_BITS: 16
FRAME_BITS: 32
CHANNELS: 2
RATE: 44100
PERIOD_TIME: (125011 125012)
PERIOD_SIZE: 5513
PERIOD_BYTES: 22052
PERIODS: (3 4)
BUFFER_TIME: 500000
BUFFER_SIZE: 22050
BUFFER_BYTES: 88200
TICK_TIME: 0
volumio@volumio:~$ lsusb -v
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 31
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Bus 001 Device 005: ID 20b1:2009 XMOS Ltd
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x20b1 XMOS Ltd
idProduct 0x2009
bcdDevice 1.20
iManufacturer 1
iProduct 3
iSerial 2
bNumConfigurations 2
bLength 9
bDescriptorType 2
wTotalLength 463
bNumInterfaces 5
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 3
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 8
wTotalLength 125
bmControl 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 41
bmAttributes 0x03 Internal programmable Clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 9
bLength 8
bDescriptorType 36
bDescriptorSubtype 11 (CLOCK_SELECTOR)
bUnitID 40
bNrInPins 1
baCSourceID( 0) 41
bmControls 0x03
Clock Selector Control (read/write)
iClockSelector 8
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmChannelConfig 0x00000000
bmControls 0x0000
iChannelNames 11
iTerminal 6
bLength 42
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 10
bSourceID 2
bmaControls( 0) 0x0000000f
Mute Control (read/write)
Volume Control (read/write)
bmaControls( 1) 0x0000000f
bmaControls( 2) 0x0000000f
bmaControls( 3) 0x0000000f
bmaControls( 4) 0x0000000f
bmaControls( 5) 0x0000000f
bmaControls( 6) 0x0000000f
bmaControls( 7) 0x0000000f
bmaControls( 8) 0x0000000f
iFeature 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 20
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 1
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmControls 0x0000
iChannelNames 19
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 22
bAssocTerminal 0
bSourceID 1
bCSourceID 40
bmControls 0x0000
iTerminal 7
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 4
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0320 1x 800 bytes
bInterval 1
AudioControl Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 2 Decoded PCM samples
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0190 1x 400 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x80000000
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 5
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 2
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
bInterfaceProtocol 1
iInterface 10
Device Firmware Upgrade Interface Descriptor:
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Manifestation Tolerant
Upload Supported
Download Supported
wDetachTimeout 250 milliseconds
wTransferSize 64 bytes
bcdDFUVersion 1.10
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 33
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 8
bLength 9
bDescriptorType 2
wTotalLength 463
bNumInterfaces 5
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionSubClass 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
iInterface 3
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 8
wTotalLength 125
bmControl 0x00
bLength 8
bDescriptorType 36
bClockID 41
bmControls 0x07
bAssocTerminal 0
iClockSource 9
bLength 8
bDescriptorType 36
bUnitID 40
bNrInPins 1
baCSourceID( 0) 41
bmControls 0x03
iClockSelector 8
bLength 17
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmControls 0x0000
iChannelNames 11
iTerminal 6
bLength 42
bDescriptorType 36
bUnitID 10
bSourceID 2
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 20
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 1
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmControls 0x0000
iChannelNames 19
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 22
bAssocTerminal 0
bSourceID 1
bCSourceID 40
bmControls 0x0000
iTerminal 7
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 5
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 2
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
iInterface 10
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Upload Supported
Download Supported
bcdDFUVersion 1.10
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 8
Bus 001 Device 002: ID 2109:3431
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x2109
idProduct 0x3431
bcdDevice 4.21
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
thank you wineds, which firmware revision you have ?. (it is visible in your front panel under "Status > Firmware revision"
My dac display says 1.1. I'll get the lsusb for you soon as I have reverted to my DietPi distro.
Edit : lsusb attached
so as far as I undertand, you are able to address all 8 output channels within linux with your unit, right ?
