Does it happen every time you connect it directly to the PC USB port?At first the connection was USB direct to my PC. This brought on severe hiss/distortion
Has anybody else experienced the same?
Sounds like it is broken. Swap the channels to make sure the problem moves with it to confirm it is the DAC.
I ended up buying an M100 seeing as no one was answering my questions. I had a odd sound output when I first connected it to my Andriod phone, very badly distorted high volume audio. I messed with the UAPP settings and that seemed to solve it. I've only connected to Windows once (win 10) and it worked perfectly, that was without any of the M100 drivers installed.
If anyone was wondering about the M100, it does auto power on and also it remembers the last input used, so it can be put out of sight and it'll just work when it's powered up.
I almost sent my M100 back to Amazon because it had a really low output volume, again if anyone is interested how I solved this - in UAPP there's a setting called "Hardware volume", this was set low, increasing it solved the volume problem, now I'm 100% happy with the M100, sounds great to me !!!
I will be waiting eagerly for the SMSL SP100 reviews, I have a Sap II Pro and I’m looking for a DAC so either the M100 or the Topping D30. I couldn’t find the SMSL SP100 on Amazon U.K. otherwise I’m sure I’d have been tempted to purchase it instead of the Sap II pro. Though I have heard a lot of people say my Sennheiser HD660S headphones don't sound great with valve headphone amps. (I have no way to test them first unfortunately)Ah. I actually have those in for review too. Had not looked in the boxes yet....
Ditto, it doesn't appear that the M100 Mk2 is getting much attention, probably overshadowed by the Sanskrit 10th Mk2 but a review and comparison would be interesting none the less. I guess the challenge is that SMSL (or someone else) would need to send Amir the product...@amirm any chance of a Review of the EES Sabre based M100 Mk2? Thank you.
Did you ever get to this?Ah. I actually have those in for review too. Had not looked in the boxes yet....
This is the problem with so many SMSL products; they just get discontinued so quickly..It seems SMSL M100 is out of stock or discontinued. Is there any similarly priced USB DAC that performs as well as SMSL M100?
This one: https://apos.audio/products/topping-d10s-dacIt seems SMSL M100 is out of stock or discontinued. Is there any similarly priced USB DAC that performs as well as SMSL M100?
