The apparent failure rate of this product is alarming.
However, these failures seem display the same symptoms, namely the standby/sleep issue. Perhaps this points to a single point of failure.
If this is the case, then a redesign would probably fix the issue.
Let's hope Amir can get a few "dead" DX3 units and figure out what fails.
This may sounds weird, but if the PS is the problem maybe one can try another socket around the house or another place to see if it turns on?
Its not the psu, anyone you sure have a 12v psu, try that one. I used it by mistake for a few hours, nothing bad happened and it worked well.Just tried that it is the same everywhere. I do not have another 15V PSU to test but I really do not believe it is power brick problem.
and companies like Schiit have good QC and support but their engineering takes a very creative approach to certain elementary things like grounding
Schiit is not exactly famous for their QC either. If there is any company that seems to be good in both QC and engineering department, it's JDS Labs, but anyways it's not like they make anything that can quite replace dx3 pro. The element with with ol switcher somewhat could, except then you are looking at $400 instead of $160.
I experienced it dozens of times.My unit has been pretty problem free until lately where sometimes when I start my computer up, it turns on automatically and shows it's connected but there's no sound via line out or 3.5mm? youtube videos also wouldn't play until I unplug the USB (guess it not actually receiving the audio packets or something), and the unit goes back to normal after a full power cycle, has anyone experienced this? I tried searching in this thread but couldn't find a similar issue
any idea what causes it? weird thing is it doesn't happen all the time, and soft power cycling (via remote or button) doesn't fix it, nor does replugging the usb. not as bad as the other issues here but shouldn't have to reach to the back to reset it all the timeI experienced it dozens of times.
Good psu supplies power with less fluctuations. Your 12v power supply works doesn’t mean topping's 15v work the same.Its not the psu, anyone you sure have a 12v psu, try that one. I used it by mistake for a few hours, nothing bad happened and it worked well.
hey, i just said it worked, for testing purposes it should be fine. i dont mean that we should use the 12vGood psu supplies power with less fluctuations. Your 12v power supply works doesn’t mean toppings 15v work the same.
So how about organizing to get your unit to me? I prefer to get one from US but a situation like yours where the problem comes and goes is ideal to try to a) replicate and b) see if variations of power/temp will make it worse or better. Happy to pay you for the price of the unit.I experienced it dozens of times.
Understood. I will swap it out for my normal one and see what happens there. I shut my machine down between uses so it will be intermittent use just the same.I once ran it continuously in my office whole night and next morning it was still working properly. @Toku also ran it for a few days under different modes and the problem did not occur.
Just want to share an interesting implementation detail and correct you that DX3's volume control, albeit digital, is just software mixing. It's not doing volume control in the analog stage.As expected, the digital volume control produces perfect response with essentially zero imbalance until you get to max volume attenuation of 99 db. No headphone amplifier using analog volume control comes remotely close to this kind of performance.
