Review and Measurements of Topping DX7s DAC and Headphone Amp
Veri
Hi men sorry for the question obvious BUT Can I have improvement if I use the XRL headphone out of my DX7s' Topping to RCA Input of my headphone amplifier?
Logically I use a cable adapter from XLR to RCA, I tell this because I see that the XLR outputs have better features than the 1/4 jack unbalanced out.
Thanks Men
You should use the line-out on the back to connect with an external headphone amplifier. Not the front headphone outputs.
XLR to RCA adapter is a terrible idea and has zero benefits or better features.
RickSanchez
Cartographer
Austin, TX
Thanks Men
I realize this is probably just an unintended language gaffe, but while few in number there are women on ASR too.
marcom22
Rome
Sorry man but why? I now i'm listening a Vinyl rip by Pbthal that sound fantastic with my Headphone Amplifier Little dot Mk2 upgraded. This one it's connected to unbalanced headphone out of my Topping Dx7s. I cannot use the Rca line out because i have a couple of active speakers attacche.
Thanks for all and excuse me for my questions.
Daimiel
HI! There are much diference between the DX7 Pro?
It's comparable in SQ with the SMSL Su8 V2 + SMSL SP200?
Thanks.
1roger
anyone know if this topping currently is the only all-in-one unit available at this price range(or lower), of decent quality. need xlr out, dac and headphone amp
Stuball
Hello all,
First post, thanks for having me.
I bought a Topping DX7S recently, in part thanks to this review. I'm having a problem where there is the occasional "sputter" when using the USB input from my Mac Mini, which eventually descends into full on horrendous distortion. This problem is not present when using the Optical input.
My set up in MacMini>USB>DX7S>JBL 708Ps / LG TV>Optical>DS7S>JBL 708Ps.
Just wondering if anyone else had experienced this problem, and if there's a known fix?
Many thanks.
Mrpong
I wonder if I press the "Line Out" button at the remote controller. This will let Dx7s work in pure DAC mode, and disable amplification/volume?
Jorj
Washington, DC
Line out disables the volume control and sets the output level either to maximum or some large percentage of maximum, which is perfect for most external amplifiers.
greeny
I connect my pair of Edifier powered speaker with this method.
gorman
Same thing applies, I guess, to my current DX3 Pro. What I'm left wondering is if there are advantages to this approach when volume control goes back to Windows (or Mac or Linux or whatever you're connecting the interface to). What I mean is we are always talking about digital volume control. So why having it in the operative system ought to be better than having it in the interface?
Mrpong
I'm using Dx7s for a while now and thinking to upgrade the amplifier by adding the A90. Anyone tries or experiences this combo (DX7s+A90)?
Joaquin Dinero
Michigan, U.S.
So I've had a DX7s for a few weeks now, and overall I love it. But I just picked up an XLR cable for one of my headphones (Final Audio Sonorous II) and its not working? I get no sound from that output.
There's not a special setting for XLR is there? I should be able to just plug the headphones in and go?
I've never used either the XLR out or the cable before, so no way to tell which is the problem. And I dont have any other XLR equipped headphones.
Mrpong
Do you mean that the Sonorous II connects to DX7s via 4-Pin balanced cable? If DX7s is not set to work in pure DAC mode, too-low volume, or in mute state, and if the cable is terminated correctly l, it should work right away.
Maybe try to press the headphone button at the remote control to ensure that the Dx7s is in dac/amp mode.
Joaquin Dinero
Michigan, U.S.
Thx. This is what I suspected.
I did check that it was in HP mode, not DAC only mode. I could simultaneously play out of the SE output, but not the XLR.
It didn't come with a remote :(
I'm gonna try a new cable --- hopefully thats all it is. I can get along just fine without the XLR, of course, but I wanted to try it.
taku1101
Hello, newbie here!
This DAC / AMP looks fairly interesting but I am wondering if its suitable to drive my Audeze LCD-2 (non-fazor model).
I'm fairly new to this whole topic but I've already read somewhere that they should get "a couple of watts" to prevent distortion at short peaks in volume.
Now on Toppings website it says the balanced headphone out can deliver 1000mW x2 @ 32 ohms.
What the hell does that mean? Is it powerful enough or not?
And I've also heard its generally recommended to have an output impedance that is around 1/8th of your headphones impedance? (Someone tell me why?)
Supposedly the LCD-2 have an impedance of 70 ohms? But other websites talk about 42 ohms?
Audeze own blog on this wasn't much help either, talking about 70 ohms...
So would the output impedance of 10 ohms of this DAC/AMP be too high?
I don't really know anymore and I'm just confused...
I just need an AMP/DAC (stack or single unit) that can drive these headphones properly and has the following:
1. Remote for at least adjusting the volume
2. Balanced pre-amp out at the back + balanced headphone out at the front
3. A switch to choose between headphones or pre-amp
thank you for reading
