and the net radio play in crappy 44 khz even when there are better quality bitrates available for the particular station.
I think you are very confused.Well, actually the WXC-50 does play in the bitrate transmitted, but the text on the MusicCast app just state 44.1 kHz for all MP3. Works fine up to 320 kHz which is the highest MP3 internet radio bitrate I have found.
To play a eg 320 kHz data stream in 44.1 kHz would require a re-sampling which requires at least the same hardware resources as just playing 320 kHz. Eg Linn internet radio seems to transmitt in 320 kHz only, there is no 44.1 channel - which is to be expected by Linn.
It is the same with a 320 kHz MP3 file, stored on a PC or NAS. Musiccast state this is played in 44.1 kHz.
It is possible to use another dlna/uPnP controller, eg "Hi-Fi cast" which states the correct data rate.
Unfortunately, the Yamaha controller has some defects. This is one such.
AAC/m4a files or internet radio are correct labeled by the Yamaha controller.
/B
Thanks! Nice welcoming.I think you are very confused.
There is no such a thing as 320 kHz data stream.Thanks! Nice welcoming.
Focus on the essentials as well
Any real problems to understand what is meant by "320 kHz data stream"? Is it really necessary to spell out "data stream stemming from a 320 kHz sampling"? Note the post I responded to, stating "the net radio play in crappy 44 khz" ( you also responded to that post ) - even though it is unlikely that any radio is playing in 44 kHz most of us understand what is meant by this.
Enjoy your weekend
//B
Q1. Is the Optical out also Volume controlled by the Yamaha?Couldn't find a reference to "speaker size" in the manual or in this thread. All the manual says is this, from page 12:
"You can adjust the volume or high frequency cut off control when the subwoofer is equipped with those functions."
So, no built-in adjustments for the subwoofer output.
Yes. In preamp Mode.Q1. ¿La salida óptica también está controlada por el volumen de Yamaha?
Q2. ¿La salida del subwoofer también se controlará por volumen mediante la perilla de volumen en Yamaha?
Yes.¿Cuál es el estado actual de Spotify Connect en el WXA/WXC-50? ¿Todavía funciona? ¿Se puede conectar sin problemas?
I have been following this discussion about the WXC-50 DACs.The above features suggest to me that with the Mode Switch in Pre Amp position you are using the ESS DAC with DSP (Digital Sound Processing), while in Player mode you are not, that you are using the Burr-Brown DAC.
This works perfectly for me on my WXC-50What is the current state of Spotify Connect in the WXA/WXC-50? Does it still work? Can one connect to it without issues?
I found a different opinion on this site:
In one discussion board I’ve read recently, Yamaha confirmed that the WXC-50’s DSD-capable ESS DAC chip is used for the PRE-OUT and all digital outputs (Optical and Coax) while the Non-DSD capable Burr Brown DAC chip is used for the AUX outs.
So it seems in either Player or Pre Amp mode, as long as you have plugged in the PRE OUT rather than AUX OUT you will be using the ESS DAC.
Hi, yes the ESS is considered way better.Are one of these dac chips considered better than the other?
I'm finding the volume on the app is almost at full volume when cranking it up a bit. It's not crazy loud and this is meant to be 50 watts per channel. These type of volumes on previous amps with similar power I'm sure I'm only half way.
Yamaha WXC-50 uses the ESS SABRE9006AS DAC.Hi, yes the ESS is considered way better.
This is true but …..I have been following this discussion about the WXC-50 DACs.
Based in Melbourne, Australia, just received my amp for a few days. Probably one of the first batch for down under lol!
Thankfully, my Wiim amp (PCB_Version: 5) is free from any of the HDMI ARC issues or noise related issue so far. Perhaps being a lesser prirority market for Wiim have some benefits for new products!
For those interested, here are my thoughts (Inc. screenshot of EQ pairing with KEF Q350 speakers) : KEF Q350 + Yamaha WXA-50 v KEF Q350 + Wiim Amp
