REW For Simple Desktop Speakers?
HarmonicTHD
What do you mean by, “. . . increase the buffers in REW”?
There is a menu in REW, I think where you also set the mic and speaker level, where you can set buffer sizes. I am traveling so I can’t send you a screenshot to better explain.
wacomme
wacomme
No always point the mic up and use the 90deg calibration file for listening position measurements.
For close in, less than 1m driver measurements, you point the mic directly at the center of the driver to be measured. Not relevant for your application where you want to correct for room modes and reflections.
Ahh. Then I need to measure again. I’ll check the CPU settings too, and if I still get the R roll off, I’ll switch monitors to see if I have a faulty monitor.
wacomme
wacomme
I’m only 2.7 ft. from each monitor - not greater than 1m. Does that matter?
wacomme
wacomme
BTW - I’m using a SMSL DO100 dac and a Topping L50 amp.
Trell
Check that you use the correct calibration file that corresponds to mic orientation in REW. Pointing mic up it should be the 90 degree one.
HarmonicTHD
Now I found it. See the manual, they provide a screenshot - see buffers are set to 16k in the example. First set the CPU to full clock speed and if that does not work double the buffer size.
wacomme
wacomme
Are you using a Topping DAC?
It's one of the reasons I use MMM.
I’m hoping the 5K dip isn’t caused by my dac, but I’ll keep the possibility in mind. However, I don’t understand why that would imply using the MMM method.
wacomme
wacomme
Should I also test L/R loudness settings for each monitor to make sure they’re even - considering that they’re equal distance from my head? I presume this is easy to do within REW and the umik-1
HarmonicTHD
There is no connection btw MMM and the 5k drop. The MMM method requires a bit less CPU power afik. Therefore crank it up.
HarmonicTHD
It would come out in your separate LR measurements anyhow.
Trell
Setting level using REW would be nice though I've not used it for that as GLM does this for me, and similar for Audyssey XT32 in my living room.
Berwhale
The auto shut off issue with the R channel on my Topping D50s DAC meant that I could not easily measure my monitors separately (i.e. without swapping cables around). This, coupled with my experience with iLoud's ARC3 software where (IIRC) I need to take measurements from 27 positions (9 on 3 separate horizontal planes) made the simplicity and speed of MMM seem very attractive.
When I compared corrections generated from standard measurements, MMM and ARC3, I could tell the difference between them, but I could not conclude that I consistently preferred one over the others. I therefore stuck with MMM as it was the simplest for me in my situation.
I should add that these experiments were carried out a couple of years ago and I have a different DAC now, so I do intend to revisit all of the above when I can find some time to do so.
wacomme
wacomme
As for the 5kHz roll off. Try switching speakers and channels just to exclude any fault with them. However I assume your computer is not quick enough. Make sure it is in full power and not energy saving or economy mode, where the CPU is throttled when not loaded. Secondly you can increase the buffers in REW. This will most likely solve it, at least it once did for me.
I checked my computer (M1 Macbook Air) and it seems to be running in full power - it's plugged in and doesn't have energy saver on. I will try switching monitors to see if there's a monitor issue.
HarmonicTHD
Did you increase the buffers?
I don’t have Mac so for PC one can switch to a mode that the CPU always runs at its highest clockspeed. Good luck.
dc655321
Can you drive the speakers directly from the Mac? This could eliminate the DAC as the source of the 5kHz drop.
Also, nothing you’re doing with respect to audio is taxing your computer. Do not be concerned.
Trell
REW won't allow different interface for ADC and DAC, but that is possible to work around in Windows with ASIO4ALL. For MacOS I don't know.
The sharp 5K drop should be quite audible though so your suggestion of another DAC ought to work for just confirmation.
wacomme
wacomme
I will increase the buffer in REW, but I don't think there is anything I can do with my Mac CPU clockspeed.
