- Thread Starter
- #341
Michael,
I read your post
about the new release.CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
I wanted to tell you if this is a BUG, or if it is the expected behavior. When I start CamillaDSP for the first time, the configuration file is not loaded in the GUI, if I try to apply or modify any changes in the interface, it returns the error message. To fix it I don't have to follow...www.diyaudio.com
I look forward to either an upgrade howto or updated install steps (probably more simple -
https://github.com/HEnquist/camillagui-backend/releases/tag/v1.0.0-rc1 and
https://github.com/HEnquist/camilladsp/releases/download/v1.0.0/camilladsp-linux-aarch64.tar.gz )
Although ongoing it would be good to have upgrade instructions.
Edit : It appears that the new release is evolving quickly and so we should wait a few days for a stable version.
I am waiting just a bit to see if there will be final version of the V1.0.0 GUI before updating the instructions. If you want to jump ahead and give it a try now all you need to do is delete your old install and re-install.
First delete all of your old stuff related to camilladsp, camillagui, pycamilladsp and pycamilladsp-plot.
Rich (BB code):
cd ~/camilladsp
rm camilladsp camilladsp-linux-aarch64.tar.gz camillagui.zip camillalog
sudo rm -r camilladsp camillagui pycamilladsp pycamilladsp-plot
Then re-install using the newest versions. You can use the same commands as before for pycamilladsp and pycamilladsp-plot but you need to update the download URLs for camilladsp and camillagui.
Rich (BB code):
wget https://github.com/HEnquist/camilladsp/releases/download/v1.0.0/camilladsp-linux-aarch64.tar.gz
tar -xvf camilladsp-linux-aarch64.tar.gz
sudo git clone https://github.com/HEnquist/pycamilladsp
cd pycamilladsp
sudo pip3 install .
cd ..
sudo git clone https://github.com/HEnquist/pycamilladsp-plot
cd pycamilladsp-plot
sudo pip3 install .
cd ..
wget https://github.com/HEnquist/camillagui-backend/releases/download/v1.0.0-rc2/camillagui.zip
unzip camillagui.zip -d camillagui
Now you just need to make a few changes. First I would edit your ~/camilladsp/camillagui/config/camillagui.yml so that default_config and active_config point to ~/camilladsp/configs/camilladsp.yml as is done in the tutorial.
Rich (BB code):
nano ~/camilladsp/camillagui/config/camillagui.yml
The other change that is worth making is editing your camilladsp.service to change the log file location. With the new GUI you can view the log directly from the GUI but the log needs to be named correctly. Update the ExecStart line in /lib/systemd/system/camilladsp.service to ExecStart=/home/michael3/camilladsp/camilladsp -g-40 -o /home/michael3/camilladsp/camilladsp.log -p 1234 /home/michael3/camilladsp/configs/camilladsp.yml, replace michael3 for your username.
Rich (BB code):
sudo nano /lib/systemd/system/camilladsp.service
Restart the services.
Rich (BB code):
systemctl daemon-reload
sudo service camilladsp restart
sudo service camillagui restart
That should get you up and running again.
Michael
