Schiit Magni Heresy
majingotan
Laguna, Philippines
You guys know that Schiit made this for schiits and giggles right? Then again I don't know how much QC effort they put on this since even Schiit themselves are schitting on this product. Then again at least you get 2 year warranty with questionable customer service for the cost of a Benjamin
solderdude
The Neitherlands
Looks well made and quite nice to me.
Just $ 99.- and a nice metal enclosure.
Measures just a little bit poorer than Archel2. More power though.
Someday, someone will send one to Amir and we get to see other measurements too.
My only comment would be the lack of DC protection (the amp is DC coupled) which would be really easy to implement given they already have an output relay in there.
solderdude
The Neitherlands
Look one post above yours and/or on SBAF
Cahudson42
How about the soldering job? Manual? Loose bits and blobs? Stuck on bits and blobs?
Or completely clean surface mount and thru hole by machine?
Does the output relay mean there is no worry about 'pops and clicks' if you don't have the volume at zero when turning on/off? (Unlike Geshelli?)
solderdude
The Neitherlands
That's what the relay is there for. It would not cost much more to use the same relay for DC protection on the output.
If only because the design is DC coupled.
Thomas savage
The Watchman
uk, taunton
The Heresy appears to be a little ball-tearer of a product for USD$99
I like the look of it. The red and black are fabulous. I think I might want one. Is that bad? :)
Christ, someone needs to restore John's sensibilities.
T
Toroid
I'm not great at reading the results. Does it appear at first glance that it's on par (or even better than) the Atom?
threni
/dev/null
On this site it would appear to be! I actually became aware of this site whilst investigating whether I should buy the Asgard 3 and despite a lot of negativity the only root cause for it I could find was moaning about customer service and a short-lived technical problem with an amp they sold 10 years ago. I wonder if, during A/B testing of a schitt amp/dac and an alternative of a similar price/generation, the haters would actually be able to identify which was which? (I subsequently bought it, and think it's great).
JohnYang1997
China
This implementation should work very well, 8 opamps per channel in parallel. But how do they have such mediocre performance (for the component they chose). They are selling it for 99 dollars so I don't think there's anything bad about it either. Adi2dac has better distortion vs amplitude with two less opa1688s. (similar circuits)
JJB70
Singapore
The guy who gets it right the first time probably failed a bunch of times before he started counting his trials.
Probably true, but that's what product development is about. By the time a product is released to customers it should be well sorted. Unfortunately in the past at least Schiit have had a habit of putting half baked products on sale and using customer experience to figure out what bugs still need to be addressed. A good and fairly recent example is the turntable mess.
No company can ever guarantee a new product is 100% sorted when it goes on sale, but companies like JDS and Benchmark put effort into getting it right before sending products to customers.
Human Bass
I guess they didnt aim to be clearer than the Atom, just clear enough with way more power. 2.4 watts @32ohms is close to "can drive anything" mark.
