- Joined
- Jun 5, 2020
- Messages
- 4,829
- Likes
- 3,761
Yeah, it's unnecessary to measure that loud. Typically I measure at 85 dB, which should be enough. Try it and see. If you have an AVR that's calibrated to reference, you should get there at the -20 MV setting.
You're right in pointing out what I'm seeing, so thanks for explaining that you're going for the Harman curve. It certainly does cause your upper bass to look depressed. Down in the subwoofer region, my own testing over the years tells me I wouldn't like the blue line as much, and would prefer your measurement, where the bottom end rises above the mid bass. It gives everything a nice weight that anchors the sound. Therefore my target would bring 60-100 Hz downward a bit and merge those two areas better. There is probably some personal taste here. I find when that region is elevated, the upper bass gets a little cloudy, including vocals. So for me it's a clarity improvement.
Is the 350-1000 Hz rise seen from your speaker in anechoic measurements?
