SMSL DO300 DAC Review
Rate this stereo DAC:
    Votes: 6 2.6%
    Votes: 9 3.8%
    Votes: 49 20.9%
    Votes: 171 72.8%
Cirodx
Technical explanation of everything is quite impossible, backread this thread and you may find some information (even if probably not understandable since they are not explained for whom doesn't know the topic)
What you should know, is that you need to select a filter for PCM and leave it as it is, since it will work for 100% scenarios.
Soundcolor may be selected as you prefer, for DSD filter is ok the default, and you can lowe DPLL to minimum value, raising it if you hear issues
That's it
ok, DPLL to minimum value? and volume -5 is that okay?
Cirodx
Is it my impression that by setting the DPLL to a minimum, the sound gains impact and dynamics?
Blashyrkh
It should not, but depends.
DPLL has no effect on USB to begin with, and on other inputs it may avoid issues with sources that has lots of jitter.
Setting 1 is the safest option, better jitter hadling but should add delay
Setting 15, no delay but worst jitter handling
As said, I don't expect any change in sound if your coax source hasn't very bad jitter
Higher values may be better delaywise if you use your dac also to watch videos
Cirodx
setting the dac volume lower than 0 the sound becomes more relaxed and more pleasant at the expense of the impact, I'm not sure how to set the volume.
DeepSpace57
Hello, I hear the static noise at some colour options. Do you have the same problem?
Cirodx
I just put the do 300 to work, will 50 hours of burn in be okay?
regarding the warmth setting: rich 1 = slight effect, rich 2 = medium effect and rich 3 = maximum effect, this is how it works or vice versa, thanks.
DeepSpace57
Do you have any static noise at Tube 1 or 2?
Veri
New SMSL DL200 ES9039Q2M DAC & Headphone Amplifier..
David_M
Has anyone noticed how the SMSL DO300 and DL200 have equaled and even exceeded the specs for the SMSL top-of-the-line SU-10 at about half price or more? All due to the ESS 9039 DAC, which kicks the butt of the already superb 9038 DAC.
Also, has anyone taken pics of the internal pcb of the DO300?
nerdemoji
In the DL200 thread there is a little bit of talk about the performance of the 9039 chip... seems ESS is going for specifically great 1khz SINAD over other specs. anyway transparent either way
David_M
Optimizing for IMD or multitone tests would have been better in my opinion, as that's more representative of actual musical content.
Blashyrkh
9039 chip or the hardware that's implementing it?
Anyway smsl internal engineering is pretty awesome for the price
