archerious
- Joined
- Aug 10, 2020
- Messages
- 255
- Likes
- 150
I thought my unit was bad, turns out the MicroUSB cable I was using was trash. The MicroUSB cable from my Firestick works wonderfully with this.
Have not had this exact issue but had issues getting my 2018 Mac Mini to see it initially for some reason.New issue, my iMac completely glitches out when I use the SMSL Sanskrit 10th MK II with it.
It works for like 1 hour then goes silent.
Restarting the DAC does no good, only restart the iMac itself gets things working.
Have my own question: Would there be any benefit powering the unit through the aux power Micro USB jack? Seems to work fine on direct
USB power as far as I can tell but I have some Apple 'sugar cube' 5W wall warts lying around; would one of those be suitable with an A-to Micro cable? I put this and a couple other questions to SMSL but never heard anything; customer service doesn't seem to be their strong suit.
noHi I'm just buy MKII and download driver V4.67 from SMSL but I' have found driver V4.86 from Topping E30.
Can MKII use driver V4.86 from Topping E30 ?
Thank you.
The sk10mk2 is not designed to be connected to headphones because it does not have a headphone amplifier in it.Using the sk10mk2 connected to my laptop via micro usb port and outputting thru RCA>3.5mm earphones...
Can anybody verify that the MK2 version supports DSD512 and 768Khz PCM?
I just bought mine. The box has red v2 with black background, the red PCM logo has 768khz in it. I've opened it and it has AK4493 chip. But 768kHz option does not appear in the Windows setting. Even the manual says it is only 384kHz and DSD256. Was I scammed or there is a third version halfway between the original and the MK2?
View attachment 86408View attachment 86409View attachment 86410View attachment 86411
