Veri
- Joined
- Feb 6, 2018
- Messages
- 9,600
- Likes
- 12,042
Shows up where? On Windows, for 768k you need to push it via wasapi or ASIO. System panel doesn't support that high of a rate.With SMSL drivers mine shows up as 32/384.
Ok thanks that's good to know.Shows up where? On Windows, for 768k you need to push it via wasapi or ASIO. System panel doesn't support that high of a rate.
enjoy it!!! Can you take pictures of the dac itself to see how big it is if compared with other things on your desk?
e30 has cleaner multitone, so I would say it is a hair better.is this better than the topping e30 when we use a generic 5v charger?
e30 better in my opinionBetter than e30 or e30 better because ...
Yes, tested and works.Anyone with this tested a Squeezebox Touch via USB, seems to work with some DAC's that need drivers but not all.
Thanks.
Thank you very much! Thats good to hear, i will have to re visit this then, I havnt looked at dacs for a while due to not knowing.Yes, tested and works.
I have it connected to a pi 2 at the moment. When I change tracks I do not notice a pop. It will remember its volume setting when powered off. I even disconnected the USB and plugged it back in and it had kept the volume. I don't have any DSD256 so I downloaded a test track and did notice a pop when switching to and from it.@silverD
Does pop-noise occur when changing tracks or when changing sampling rate?
Are there any problems with the DSD256 files?
Will it remember volume setting if it is powered off and back on?
Some of these problems occur with the Topping E30.
Hope this helps.
This mist be an error: micro USB is by far the weakest, both based on my personal experience and by looking at the built.Quote>> "I am not a big fan of the micro-USB connectors but they work."
The last time I spec'd mini-USB compared to a full size USB-A plug the mini was rated for more insertion and removal cycles. So the mini has some advantage there for longevity.
"Standard USB has a minimum rated lifetime of 1,500 cycles of insertion and removal, the mini-USB receptacle increases this to 5,000 cycles, and the newer Micro-USB and USB-C receptacles are both designed for a minimum rated lifetime of 10,000 cycles of insertion and removal."
https://en.wikipedia.org/wiki/USB_hardware#Durability
I rolled eyes when I first saw it but if it's by insertion and each one done properly one will be better than the other and just maybe the micro version is the better one. Otherwise wikipedia.org or the author(s) should be advised of the error.This mist be an error: micro USB is by far the weakest, both based on my personal experience and by looking at the built.
Hi guys,
I just received the MK2 from Amazon. I was expecting it in 2 weeks time so I don't have RCA cables for my speaker. I tested it with an old RCA cable I found in a draw (it looks really thin, but the connectors fit).
Anyway, every time I play something from the laptop via the new DAC, my speaker start making a noise that is audible when music is playing and stays when the music is off. It's not "loud" but very audible and really annoying. At first I thought it was because I wasn't using the auxiliary power input, so I tried with that too... but the noise is still there.
I used the OTG dongle of my phone as an input and it's dead quiet.
How can I clean the USB output of my Laptop? Not sure if it's a noob question but I'm completely new. This is my first external DAC.
Cheers!
Rob
