So, how to solve the 20khz phase shift problem of Class D amplifiers? ? ? Use a Class AB amplifier instead?
Status
Not open for further replies.
AnLaoJin
AnLaoJin
China-HeNan
At present, the most suitable place for Class D amplifiers is still the subwoofer, not the full frequency.
March Audio
Albany Western Australia
There is no phase shift problem with Hypex or Purifi.
Once you join the dots and understand the relationship between phase frequency and time you realise its a non issue if the change is linear wrt frequency.
Q: Class D has achieved very low levels of distortion, but is it possible for class D amplifiers to continue their evolution into something close to a straight wire with gain, i.e. minimal phase shift in the audio band? (A similar question from maty).
Bruno: The 1ET400 module has the frequency and phase response of a 2nd order Butterworth filter cornering at 60kHz. If you look at the phase shift of that, it’s very nearly “linear phase” in the audio band. To take some rough numbers, it if you have a circuit that has a 0.2 degree phase shift at 200Hz, 2 degrees at 2kHz and 20 degrees at 20kHz, that’s the same as saying it has “0.001 degree per Hertz” phase shift. That’s another way of saying that the whole signal is simply delayed by 2.8 microseconds. If you plot phase shift on a linear frequency scale that’s immediately obvious because you get a straight line. Of course a simple delay doesn’t change the sound. It’s literally the same as starting your music a few microseconds later.
Lars: My dad used to say that if you left a CD in its case without playing it back, it’d just sit there accumulating massive amounts of phase shift as time went by.
Bruno: What that matters to sound is how much phase shift differs from a pure delay. Anyone who’s ever done phase measurements on speakers will remember that you have to remove the time-of-flight delay from the data, for instance by marking the leading edge of the impulse response. Otherwise the linear phase shift corresponding to the distance between the speaker and the mic completely clouds the picture. In the case of the 1ET400 module it’s just under 1 degree at 20kHz. There never was a phase shift problem in class D, it’s simply a trick of the light that happens when you plot the phase response on a log scale without removing the fixed delay
Matias
São Paulo, Brazil
QMuse
Otherwise the linear phase shift corresponding to the distance between the speaker and the mic completely clouds the picture. In the case of the 1ET400 module it’s just under 1 degree at 20kHz. There never was a phase shift problem in class D, it’s simply a trick of the light that happens when you plot the phase response on a log scale without removing the fixed delay.
Before going any further with this thread I think OP should demonstrate his understanding of what has been said above. If he doesn't understand this all future discussion is futile.
Matias
São Paulo, Brazil
What is more impressive is that this is a technical forum and this nonsense keeps showing up every few months again and again...
Status
