Sound Town ST-UPDM4C (4 Channel Pro Amp)
Rate this amplifier:
    Votes: 134 94.4%
    Votes: 7 4.9%
    Votes: 0 0.0%
    Votes: 1 0.7%
This is a review and detailed measurements of the Sound Town ST-UPDM4C four (4) channel professional amplifier. It was purchased new by a member and drop shipped to me. It costs US $540.
As you see, there is a bit of style to this amp with the front panel. This is a straight amplifier with no DSP:
The fans came on immediately and made moderate amount of noise (much quieter/lower pitched than many small fans like this). As you see, input is XLR and output is speakon connectors.
I was very pleased to see Audio Precision analyzer graphs in the manual. They were quite tiny and hard to read but made me hope that the design was verified through such.
Sound Town ST-UPDM4C Measurements
The tests you see are all performed using Channels 1 & 2 on one side. Let's start with our dashboard:
SINAD is below average of all amplifiers tested by 4 dB but for a Pro amplifier, it is not bad:
But there is more going on here. There is broad set of noise between 2 and 4 kHz. I shut off the signal feed to it and was very surprised to find this noise component:
Seems like some square wave with harmonics buzzing around internally that is bleeding into the amplifier. Not good.
That noise limited the signal to noise ratio:
It also showed up in multitone test:
Notice how the ends of the spectrum has reduced levels which indicates non-flat frequency response:
Sound Town ST-UPDM4C Measurements Frequency Response Four Channel Amplifier.png
Not only do we have (speaker) load impedance dependency but we are missing the lows as well below 40 Hz or so. As such, you can't use this amplifier for subwoofer duty.
Amplifier is rated at huge wattage so I was shocked to see so little output with 4 ohm load:
Sound Town ST-UPDM4C Measurements Power into 4 ohm Four Channel Amplifier.png
Sound Town ST-UPDM4C Measurements Max and Peak Power into 4 ohm Four Channel Amplifier.png
I am used to seeing power exaggeration in pro amplifier specs but this is in entirely different class.
Strangely, I got identical amount of power into 8 ohm load:
Sound Town ST-UPDM4C Measurements Power into 8 ohm Four Channel Amplifier.png
Is there some kind of limiter in the unit? There must be. See what happens when I change frequencies:
Sound Town ST-UPDM4C Measurements Distortion vs Frequency Power into 4 ohm Four Channel Amplif...png
See how the curve goes up but then starts to go backward below 1 kHz? That is electronic limiter in action.
Finally crosstalk was very poor:
Conclusion
I have hardly seen any audio device show issues in every test I run but here we are. I don't understand what is going on here. How can they have analyzed the performance using AP yet have so many issues left on the table? Did they design change post those measurements? This is the frequency response from the manual:
It shows flat response to 20 Hz. Notice the date is 2003. Is it really that old of a design?
Anyway, I can't recommend the Sound Town ST-UPDM4C.
HiFidFan
U.S.A
Wow.
Thanks for the review @amirm
enricoclaudio
Houston, TX - USA
Another that bites the dust!! Thanks @amirm for another revealing review!!
peniku8
The website states "4 X 950W". I'm sure they don't mean "four times 950" but instead mean "4x=950W", while "x" is the amount of power available per channel. Solve for X and you get x=238W per channel. Actually on point for the 4R test, just gotta do some math!
Jokes aside, that's some pathetic amount of power for the price, would much rather get a few Behringer amps. But I guess it's attractive for a lightweight monitor amp. 4 channels with 200W each is plenty for stage monitoring. And 1U is interesting for those who try to keep their racks small, but at that point I'd much rather go with active speakers (and I did).
PatentLawyer
Deep in the Soundstage
When you see the exit ramp for Sound Town, keep on driving.
Madjalapeno
NH, USA
Amazing you can fit that in a 1U rack mount, just a shame about the performance. The FR is appalling for something considered professional.
Might explain why some songs sound so aweful if this is in the studio, rather than a mobile disco.
enricoclaudio
Houston, TX - USA
Pretty sure the ART SLA-4 performs better than this one. It’s also cheaper!!
Steve Dallas
A Whole Other Country
I'll just go ahead and get this out of the way... Maybe Amir got a defective unit! Or his AP is broken! Or he forgot how to use it!
YSC
Conclusion
I wondered about the "not bad for a pro amp" thing, why is audio so weird in that pro stuffs works worse than hobby stuffs.. isn't pro stuffs usually more robust, perform better and lasts but looks bad and with user unfriendly controls?
Chrispy
PNW
I wonder what it must be like being a professional in this industry, going in more blind than would-be audiophiles into purchases.
How many professionals actually buy this brand?
Chrispy
PNW
What is special about a "pro" amplifier? And why are expectations different for "pro" than for home audio?
I've always thought the consumer amp crowd just figured theirs would be better....because.
Chrispy
PNW
They're usually feature rich compared to a consumer amp.
ps....but not as "pretty"
tmtomh
@amirm can of course speak for himself, but my understanding is that if you look at pro-targeted amps like the Crown Class D models, they sacrifice distortion and noise performance in order to provide gobs of power in a low-profile, not-too-expensive package.
Of course this one is a trainwreck, but the low SINAD would be consistent with the pro amp approach, if this amp had delivered lots of power and good frequency linearity (and had not had that bizarre mess in the upper-mids even with no signal feeding it).
Chrispy
PNW
I've never heard of the company. As far as I can tell, it's a no-name brand sold through vendors like Amazon and Aliexpress. It might as well say "Ultramax" or "Power Plus" something on the front panel. I'm surprised it didn't blow up in testing.
Yeah pretty much my impression.....someone who read the marketing and thought it was a good idea to buy?
