- Joined
- Sep 4, 2019
- Messages
- 1,172
- Likes
- 2,323
I am quite aware that biases and preconceived notions go both ways. I am also quite aware that Danny spews a lot of BS. His belief is that what he is hearing from "upgrading" (modifying) loudspeakers isn't a change in FR but from the materials used in the capacitors ("air" -- "soundstage" -- etc.). In order for really expensive capacitors to actually sound different, they'd have to add so much to the stray circuit elements that they would have to be a radical deviation from the ideal component. A "high end" capacitor is just like a "high end" cable. Do you want to talk values? Danny doesn't even believe in double blind listening tests... Personally, I cannot take him seriously. Just because he makes well designed loudspeakers that sound great does not mean that he cannot believe in pseudoscience. He does. As mentioned above, if screenshots are necessary, I will post them. In the meantime, I'd suggest you rewatch all of the videos he's featured in on New Record Day and actually listen to what he's saying.
I am not claiming that he doesn't believe in psuedoscience. What I am pointing out is that your statement that "He is 2hrs from me and I’ll actually be visiting so he can give me the run around... " strongly indicates that you have preconceived bias that brings into question the validity of any observations you may have. You have already decided that there will be no differences and will therefore likely hear none. This is no different than someone who goes with the expectation it will make a difference and hears one.
There is also the additional factor (at least in the case of the Klipsch mods) that he has changed the speaker's frequency response and phasing, both of which should be observable. Outside of blindly listening to two speakers with the same crossover values and only the type of components changed, it is impossible to know if the changes in the sound are from frequency response and phase changes or the component changes.
Given the foregoing, my question is: What do you expect to get from visiting Danny? Given your views, his views, and the inability to conduct any type of blind listening, the outcome is pretty certain: Both of you will spend time to reach the same conclusion you each already have, but with higher blood pressure and having lost a day of your life. For the subjectivists listeners, they will conclude what they already have: you are deaf (I am not saying that, just reciting what their argument will be) and Danny is doing great work. For the objectivists they will conclude that no conclusion can be made because of the preconceived biases and sighted tests. There is of course the possibility that you will hear a difference, but I think that is highly unlikely.
