Starkrimson® Ultra Amplifier Modules -- 250/500W into 8/4ohm
orchardaudio
orchardaudio
Succasunna, NJ
Nice ... do you have efficiency data for rev 2.0 modules and compare both on the same graph?
No, power stage efficiency for Rev 2.0 should be very close or the same as that has not changed.
With Rev 2 modules it is much harder to measure efficiency as they require 5 supplies.
Also, are power/distortion specs still the same?
Yes. No change.
What did you do to increase module efficiency, if it's not a trade secret? Optimize the PWM switching speed?
I did not do anything. I am saying that power stage efficiency is higher that what is shown in the graph if you subtract the power taken by all the op-amps and safety circuits and so on.
orchardaudio
orchardaudio
Succasunna, NJ
Rev 3.0 Multitone, identical to previous rev here:
tomchris
Denmark
Hi,
I am looking into building high current monoblocks capable of driving low impedance ribbon speakers possibly down to 1 ohm.
I know that the Starkrimson modules are 2-ohm stable and capable of 20A peak current, however have you done any test of what is achievable of the GaN FETs when is come to current delivery at lower impedances such as 1-ohm?
orchardaudio
orchardaudio
Succasunna, NJ
Hi,
They will drive 1ohm load you will be limited by the 20A peak current still, also efficiency drops with 1 ohm load, so you will probably want additional heatsinking.
David_M
Yes. No change.
But to an end customer, all we see are the effects of drawn AC mains and heat dissipated by the amplifier as a black box. So, in that regard, Rev 2.0 is identical to Rev 3.0? If not, what's the difference between the two PCB revisions?
BTW, your plot should be efficiency vs power not Efficiency vs efficiency :)!
Slightly off-topic... but what are the channel separation specs of your stereo ultra system ? It'd determine if the layout/wiring of the modules within the box is optimal.
restorer-john
Rev 3.0 Module Images
Incredible images. Has to be the best nude PCB shot I've seen :)
So, the temp sensor on only one pair of GaN OPTs? What does the other side of the PCB look like?
Three LEDs? Overcurrent, thermal and DC?
orchardaudio
orchardaudio
Succasunna, NJ
It is efficiency vs output power.
The difference between the PCBs is that Rev 3 only needs +/- 40V supplies, where as Rev 2 required +/-40, driver and op-amp supplies a total of 5. Also rev 3 has a 12V trigger input.
Its just a heatsink on the back, ill post picture later.
Sel53
Hi folks,
I haven't seen this anywhere ... do we know what the Ultra output power will be into loads less than 4 ohms? For instance, speakers that dip to 2 - 2.5 ohms at lower frequencies?
Thanks
orchardaudio
orchardaudio
Succasunna, NJ
Hu folks,
I haven't seen this anywhere ... do we know what the Ultra output power will be into loads less than 4 ohm? For instance, speakers that dip to 2 - 2.5 ohms at lower frequencies?
Thanks
The amplifier is limited to an output current of 20A peak or 14.14A RMS. Hence the maximum RMS power into 2 ohms is 400W.
schubert
orchardaudio
orchardaudio
Succasunna, NJ
Yes, they are all 4700uF, if you have a single power supply for both modules then you can only use 4 caps per board instead of 6.
