Stylus Wear evaluation: "Cat's eye" method
sq225917
Have you gents tried taking multiple shots to stack the focus?
BDWoody
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Right, but aside from there being light refraction you can't really see anything.
New and worn out elliptical at 200x on a SEK-2:
So...yeah. I should probably just stop thinking this is going to be of any value.
Time to send them to someone who isn't going to be guessing.
Thanks for the help!
Helicopter
Michigan
Helicopter
Michigan
That looks like serious business.
The two things I run into trouble with using a digital microscope are the difficulty in getting the object into focus, and the difficulty in positioning the scope when the objective is in situ. You can’t always get a good viewing angle and viewing distance when the cartridge is mounted to the tonearm. And VERY fine movements can send the object out of focus or out of the field of view. You have to solve those problems before you can develop an efficient work flow.
Just opened this up this morning, so I am not an expert, but I find a little finger pressure on the base works for the last fine focus when capturing the image. I can capture video with mine too, so that is what I would use if I wanted to go through the stack of focus options.
Helicopter
Michigan
The first image is a Tonar 6097-DE replacement for a Shure White Label with almost zero wear; maybe 4 sides.
Other than just being fun to look at, what decisions do y'all plan to make based on these pics?
As of this morning, not buying so many replacement styli.
Here is the original stylus from the White Label:
Helicopter
Michigan
Probably going to throw the carbon fiber brush in my box of LP gear and use a magic eraser almost exclusively now. It works 1000x better on little fibers and fuzz.
JeffS7444
I think it was Shure that used to advise viewing viewing from the front to detect any dimples worn into the profile of the stylus. I'll try to provide a photo of that later.
If anyone wishes to get a lot fancier, Amscope has some moderately priced solutions, and a stereo inspection microscope with trinocular head equipped with USB camera would be the ticket, but don't go overboard with the magnification as we're not looking at cells, but a relatively huge stylus, and the greater the magnification, the shallower the depth of field is going to be.
BDWoody
BDWoody
Chief Cat Herder
Moderator
That I need to send mine to someone who has a clue.
JeffS7444
Not a bad idea, but with my setup, it's difficult to precisely focus at higher magnifications, and impossible to do so without causing everything else to shift.
Helicopter
Michigan
AT-440MLb has nice facets that show up clearly.
BDWoody
BDWoody
Chief Cat Herder
Moderator
Ah, the perils of vintage cart ownership.
I exchanged my AT ART7 for an ART9XA via AT's exchange program -- got 50% off trade in credit, no questions asked.
Since the selection of new T4P cartridges is quite limited, I'm hoping to keep my handful of decent ones in good condition. Since both the 310MC and 205CMK3 are considered worth keeping, I really should just get them both retipped and not have to think about it for a while.
For the Kenwood, the VM540 is the best cartridge I have. Since I have very little self control, I am now looking into what would be a nice MC that I can settle into for that table.
Helicopter
Michigan
JP
Brookfield, CT
Sorry, no. At that level of mag you’d be looking for a couple specs of dust right at the very tip.
