This is a review and detailed measurements of the SVS Ultra 2-way Bookshelf speaker. It is on kind loan from a local member and costs US $999 for a pair on Amazon including Prime shipping.
The sample I received has wood grain but what is on sale is glossy finish:
There are dual binding posts in the back:
There is not a lot of clearance to usncrew/screw the binding posts even for my narrow fingers.
I used over 800 measurement point which was sufficient to compute the sound field of the speaker. Measurement axis is the tweeter center.
Temperature was 78 degrees. Measurement location is at sea level so you compute the pressure.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Spinorama Audio Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Response is generally smooth but deviations flat on-axis are quite broad. This means that more musical notes hit them and hence much more audible than "high Q" narrow variations. Emphasis is from a few hundred hertz to 2 kHz and then above 8 kHz or so.
Sensitivity is higher than typical reaching as high as 90 dB at some frequencies. Given the core business of SVS is subwoofers, perhaps the design goal was for these speakers to play loud and if that means deviating from flat on-axis response, so be it.
Interestingly, important early reflections add up to a smooth response:
Putting the two together we get what we already saw in on-axis response analysis:
We have simultaneous "warmth" and "brightness" depending on how you draw the trend line.
Impedance is on the low side as it is typical of this size speaker:
I did not try to optimize the waterfall display so here it is with default parameters:
As it is, it shows persistent resonances at a number of frequencies. Of course if I raise the display floor, they can be reduced or eliminated in the measurement.
Driver Responses
I put the microphone very close to the tweeter, woofer and port and recorded a full sweep:
It seems that the boost in upper frequencies to midrange is due design of the crossover and possibly the resonance in the port. The former could have been designed out so one has to assume it is intentional. Here is the crossover:
EDIT: looks like above is for their tower speakers, not bookshelf that I tested.
Lots and lots of parts in there although all inductors are iron core making me wonder if they will saturate.
Speaker Radiation Pattern
Let's analyze how the sound radiates horizontally relative to tweeter axis:
Focusing on the red line, ideally that would be horizontal and not have the ups and downs. The woofer is getting directional as we approach the 2 kHz frequency whereas the tweeter is at the other extreme, with wider directivity so we have a discontinuity. Beamwidth widens, then narrows, then widens again. Not a good thing in general.
This is less revealing in our heatmap graph of the same:
And here is our vertical performance which is less critical than horizontal:
Speaker Distortion Analysis
Let's start with Klippel system distortion measurement at 86 dB and 96 dB SPL @ 1 meter:
My threshold is 0.5% at 96 dB SPL and the SVS Ultra more or less meets that above 100 Hz which is good. Here it is at an absolute level:
Switching to Audio Precision with our deep dive into distortion we have the following results (these tests are being refined):
Dynamic amplitude compression is very gradual and never falls off the cliff:
This should let the speaker play quite loud without bottoming out as small speakers typically do.
Distortion at 100 Hz tone is reasonable which we could tell from previous Klippel measurements:
Sweeping the full audible band at five different levels we get:
I am not trusting the above graph much as it seems to show distortion his higher than lower levels??? I did have to re-calibrate my system so maybe something went wrong there.
Here is our 32-tone test simulating "music" at two playback levels:
Distortion sadly increases where our hearing is most sensitive (2 to 5 kHz).
Here is IMD distortion versus level:
Subjective Listening Tests
My instant reaction to the sound of SVS Ultra was that it sounded "warm." The upper bass frequencies that exaggerated give an immediate pleasant impression. Alas, that quickly went away and while I could hear the appeal of it, it caused everything I played to have the same characteristic which was not right. At the same time, female vocals had very sharp extensions that were almost painful to listen to. This would come and go of course as the singing went along.
I played with EQ but after a while I gave up. Strangely no matter what I did, I could not get rid of the brightness in vocals. I did bring down the upper bass and lower mid-range level and that mostly helped but then it exaggerated the highs.
On positive front, the SVS Ultra can play really loud with good bass capability. I could get it to start to bottom out but that was at every high playback levels.
Having looked at the measurements first before listening, I thought they would either sound good "out of the box" or do so with just a bit of EQ. That did not happen. Try as I did, I could not like the sound with or without EQ. Yes, I could see the appeal of boosted upper bass in giving "warmth" to the speaker. But too much of that was well, too much of a good thing. I am puzzled where the sharpness was coming from seeing how I could not tame it. Perhaps directivity error was causing this.
I can't recommend a speaker that doesn't sound good to me and that is where I stand with SVS Ultra. I suspect measurement score will be good, making me look bad. So be it!
We have a ton of harvest from our garden. Now need to preserve them by canning them and need money to buy those supplies. Otherwise we won't have anything to eat during winter. So please donate what you can using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Driver Responses
