The Making of Martin Logan Electrostatic Speakers
Pretty neat video of manufacturing of Martin Logan Ethos electrostatic speakers. Love the automation for the box enclosure. Interesting that they rely on VHP tape to hold the panels together.
watchnerd
Seattle Area, USA
I have two sets.
The panels are great, the crossover and woofer mating varies a lot from model to model.
I really really wish they would move the line DSP crossovers and active amps -- the subs on the upper models are all active.
There are still a few things that electrostats (from Quad, Sound Lab, etc, too) do better than dynamic drivers.
Blumlein 88
Knew a fellow who built his own motorhome after retirement. Metal frame all the way. Exterior was stainless diamond plate. Held on with VHB 3M tape. Last I saw it the motorhome had 38,000 miles and the heavy stainless panels were all in place. I seem to recall somewhere they stuck aluminum panels together with VHB tape, and when torn apart the metal gave way before the taped areas did. Main issue with VHB tape is shear. The motorhome had a very small number of rivets to prevent that issue.
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
There are still a few things that electrostats do better than dynamic drivers.
I'm all ears... There's notta lotta panel talk around here.
We're at a Scientific Disadvantage what with their dismal Listener Preference Ratings and all...
Guess what M stands for?
Blumlein 88
M.....................maybe...................mutilated..............mangled..................monstrous.........................miserable........................missing....................sound quality?????
RayDunzl
Central Scrutinizer
Riverview FL
Misinterpreted... Misunderstood... Misapplied... Misused... Misread...
dallasjustice
Dallas, Texas
I've often wonder about that Harman listener preference test where the MLs did so poorly. I hate that somehow all electostats have to take it on the chin for some old ML panel. My guess would be that the ML tested was an old beaming panel. The newer ML recently tested in stereophile and also the Quads have a much better power response. So my guess is that they would perform much better in the Harman listener preference lab.
RayDunzl
Central Scrutinizer
Riverview FL
I don't think the "beaming" would change with the newer panels, they seem mostly cosmetically changed to me. Clear instead of black "spars" between panel segments, different hole pattern (more but smaller holes) in the stators, same 30 degree cylindrical arc section, though, and essentially the same mylar diaphragm material (conductive coating may be improved, maybe it's thinner, or stretched differently).
I think, in the Harman Test, in a single speaker configuration, after being "trained" to listen for "wide smooth dispersion" the cones and domes may have a little advantage.
If two speakers were used, there might be some "filling the gaps" coming from the other speaker.
I don't hear much difference in the two-speaker comb effects here between the ML and JBL. But I don't have everyone else's HF hearing.
If I put on some correlated (mono) pink noise using two speakers, both ML and JBL have about the same "problem" with combing effect when moving my head left and right on and off axis and through the centerline.
I hear sheee shooo shough shoo sheee about equivalently with either while moving back and forth.
When measured with a single mic, the ML may be at a disadvantage - they interfere with themselves because the source is not so much a point or line but a several inches wide panel. JA usually notes this in his measurement comments. The sound from the sides of the panel arrive at different times than from the center of the panel, so there's some comb filtering with itself.
"Real" sound sources are rarely "point" sources, so...??? A firecracker is, a piano is not, a guitar is not, a violin is not, a drum is not, a voice may be, a choir is not, and so on...
Measurements from Sterophile:
20+ years ago - 15 inch wide panel - the generation before my speakers, probably about the same, though. Crossover at 125Hz 9off scale from the measuring range) and 180Hz on mine (would also be off scale):
ML Monti - newest speaker with the modern X-Stat panel with comparable measuring display, slightly narrower panel (11.3"), 340Hz crossover:
I don't see a radical difference, maybe you do...
A JBL cone and horn, with what would look like more limited horizontal dispersion, 3-way with 750 and 3khz crossovers:
About the same rate of attenuation off-axis, but smoother looking in the measurement, except at the mid-tweeter cross.
The newest ML Renaissance 15 - JA didn't have all his tools, so not the same display, and not normalized to the on-axis measurement, 15" wide panel:
When I listen to my little JBL 308 vs ML critically at the sweet spot, it's like switching on some electronic "stereo enhancement" mode with the JBL, but if it were something I'd switched on, I would turn it back off after a few minutes. It is probably room reflections doing it - spatially vague to my untrained ears. ML makes what initally sounds much narrower, but isn't, more like "farther away", and to me, much more stable and lifelike.
Off axis they're fine, I listen to either set of speakers and acclimate very quickly. Listening to JBLs off-axis right now, they sound fine.
I took that test twice without any such training. Here is a picture I took in one of those two occasions:
RayDunzl
Central Scrutinizer
Riverview FL
The King of Audio should require no training in any audio matter.
That looks like the JBL I mentioned above on the right.
I remember the picture, I didn't know it was yours personally. I'm glad you took it. I had tried to find it again recently, and couldn't.
Google has no opinion of it other than it is a jpeg. Maybe adding a tag or two would make it more accessible.
"Harman tester singles out a Martin Logan speaker for public derision and punishment because it is different."
