dc655321
- Joined
- Mar 4, 2018
- Messages
- 1,597
- Likes
- 2,236
Why should headphones be anything but flat?
To compensate for the absence of the room and acoustic interaction with the outer ear (pinna, etc)?
Perhaps. I would just like to have a valid acoustic or psychoacoustic explanation for it.
Hello,
In this forum we see specific measurements posted regarding many devices.
Recommendations are made on the basis of these measurements. All very scientific, which I like.
I mean who would buy a Car on a vague concept "how it drives"?
We know top speed, torque, mpg etc. and can rely on these together with convenience features (how many cup holders, size of the trunk and how easy to access) a shape and colour that pleases us to get a good choice.
No need to test drive, right?
Now with a car I can follow the value of these measurement numbers. I can understand why a car with good torque, top speed, mpg and convenient layout would be reasonably recommended over one that falls down in one or several of these areas, though it has not stopped the buying public from buying inconvenient and inefficient cars, myself included and yes, I test drive and decide ultimately on many factors including how it feels driving on what I buy.
While the measurements presented here seem of a similar kind (Distortion, Noise, Jitter), I would ask for the scientific background.
If we elevate specific qualities as a measure of the recommendability of a device to listen to music with, there ought to be good scientific evidence that shows that lower distortion is always better sounding, that lower noise is always better sounding and I mean not in a relative sense as in: "Above a certain limit lower distortion always sound better" or "Above a certain limit lower noise always sounds better", but in the absolute sense in which it is presented here.
Alternatively, if these is a consensus about what levels of distortion, noise and jitter are actually audible, it would be interesting to know what they are and how tested devices results compare to those limits.
Also, if there are such limits and all tested devices are below the audibility threshold, should recommendations based on the measurements still be made?
Ideally the proponents of "low distortion uber alles", "low noise uber alles" and "low jitter uber alles" simply have reliably scientific tests to present that support their position and then we can continue measuring and recommending on this basis. My own research failed to provide such tests and evidence, however surely no-one scientific inclined would test result based recommendations without good and solid evidence that these test results are meaningful in the context.
Magnum Innominandum
I honestly don't know why you are on this particular forum but if you want to tweak the sound of your HD6XX I would recommend you check this software out: https://www.sonarworks.com/truefi I own it and it's quite interesting. Not something I use often but it is interesting. I personally own the HD6XX and feel that the bass response is good... adding more sounds like a bad idea to me.
These headphones are obviously lacking in deep bass. They have plenty of mid bass.
This whole discussion of heavy bass enhancement on the Senn 650s has me a bit confused. Now I have never heard anything like these recommended curves, but my Emotiva DC-1 has a built in (defeatable) 2 db boost at 20hz and the bottom end on my HD650 sounds very good to me. My imagination tells me that another 5 db "or more" might sound a bit heavy and excessive sending it's effects into the lower midrange. Guess I'd have to hear it to understand for sure.18dB is not needed at al. It is waaaayyyy too much.
That would make it a basshead headphone !
+7dB is more than enough otherwise the HD650 starts to sound bloated and 'fat'.
I've heard great things about the 660s, I would love to hear them. The 58X are fairly similar to the 6XX.The Sennheiser HD 650's and the Sennheiser HD 660 S's deep bass sounds excellent to me if turned up, as I have already said. I have owned duller open headphones such as the Audeze LCD2 and the Sennheiser HD 58X, but I did not like them as much.
I like the Dekoni ear cushions. I have leather ear cushions on my Sennheiser HD 650's and I have leather ear cushions for my Sennhesier HD 660 S's coming soon. I do not think that these ear cushions affect the sound significantly, but they maybe add a tiny bit more bass.
Imagine that, we have difference of opinions.Nope, they are much duller.
I'd give mine but I have to keep that secret till next months issue.
Boy has this debate on Senheiser EQ made a mess of this thread supposedly to investigate
The relevance of measurements to audible quality of sound
.... I would just like to have a valid acoustic or psychoacoustic explanation for it.
1 resistor of 120 Ohm between the output + of an amplifier and the plug ring (and left channel tip) of the HD6XX One of the - connectors (assuming the amp is not balanced) to the common of the headphone plug.
+ in parallel to the headphone (so from ring to common and also one from tip to common a series circuit consisting of a 12 Ohm resistor + 47uF capacitor.
Should you want to try the 7dB boost simply change the 12 Ohm for 47 Ohm.
Tip: use a 100 Ohm potmeter and make it stepless, dial it in and measure the resistance to know how much boost is needed.
I would still like more answers and especially the scientific research upon which they are based, just out of intellectual curiosity.
Looking at the Olive/Welti research regarding headphone target curves it seems very solid to me, well executed, using large number of listeners and solid statistics. Which is why I am considering to take their recommendation "on faith" and just follow it.
I had expected more suc research on subjects like distortion audibility etc. to underpin the relevance of measurements and why we should aim for specific limits or why we should always try for the best.
Yet so far no solid research has been cited and it seems limits are a matter of who you ask (everyone has a number they work with) and Amir kind of measures because he can measure and recommends on the concept of "better engineering", which kind of makes sense to me but seems just another belief (better engineering is desirable in the context of good sound).
Magnum Innominandum
Magnum Innominandum
